ImClueless's Avatar
Question Conversion questions ?
What would be involved, and how hard would it be, to put a 16 valve head on a 1987 951. It has a stock 8 valve head. I was just wondering if its possible, and would there be any benefits.
Lon, Im Clueless, Elliott
1987 944 turbo Guards Red
http://committed.to/speed
the home page is a work in progress
Old 01-03-2003, 02:54 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
It wouldn't be very easy as the coolant passages will not line up (machining required), intake nor exaust will not bolt up. Since obviously the cams won't bolt up either, pretty much nothing is bolt on...
Ahmet
Cheers!
Old 01-03-2003, 04:20 PM
Oh man, what are you thinking? You're too anxious about the car!!! Believe me you'll be more than happy with it w/ just some chips(for atleast a little while). The turbo is highly addictive, you've been warned! Plan on spending more money to upgrade it later down the road.
Old 01-03-2003, 04:36 PM
ImClueless's Avatar
LOL, i hear ya high boost. I mind says basic rebuild. make the engine strong, make it last. But my heart says, maf, chip, boost controler, and list goes on and on..
Whats a guy to do...
Old 01-03-2003, 05:21 PM
ImClueless's Avatar
so after i get the engine rebuilt. what should be the first mod. somthing subtle yet i want to notice it..
Old 01-03-2003, 05:24 PM
Here's the three most inexpensive bang for the buck upgrades:
#1 $290 Guru computer chip upgrade w/ reliaboost(like a lindsey boost enhancer) also includes 3 bar fuel pressure reg.
#2 $225 test pipe(eliminates cat)
#3 $250 deltagate wastegate
Old 01-03-2003, 06:21 PM
ImClueless's Avatar
ok, thanks high boost, what is a 3 bar fuel pressure reg. And what kind of HP gains would i see if i do all 3.
Old 01-03-2003, 06:31 PM
instead of having an adjustable fuel pressure regulator($160), this one is preset at 3 bar or 43.5psi.
Old 01-03-2003, 06:46 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Highboost....
So what would the real world numbers be for that kind of a mod on a stock turbo 217/~185 rwhp?
What does the guru chips do ?? What does it actually change ? A/F mixture etc...
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-03-2003, 07:05 PM
Oops, didn't see the hp question. At least a 20%
Old 01-03-2003, 07:25 PM
Yes, a/f ratios, ignition timing advance and retard, yadda yadda
Old 01-03-2003, 07:26 PM
Oops, the main thing is the level of boost of course.
Old 01-03-2003, 07:27 PM
Scott R's Avatar
Mine has all of the bells and whistles that HighBoost recommended, they are right on! I only wish that guru had been around when I purchased my chips.
Last but not least, don't forget to add a superior suspension to handle all that power.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-03-2003, 07:46 PM
ImClueless's Avatar
how high does it kick the boost and will my stock engine handle the increased boost, and will my stock 951 injectors handle the 3 bar fuel pressure.
Old 01-03-2003, 08:24 PM
Scott R's Avatar
I am running 14PSI at 5000 ft. This is with a wide fire headgasket that I installed last year.
Depending on the wastagate and controller, and engine management you can get 20 our of the stock motor. I think Wolfpri, and Grommit may have been running more on their "monster 951." Check the archives.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-03-2003, 08:32 PM
ImClueless's Avatar
i was hoping to run 15 or 16 without problems, can it be done?
Old 01-03-2003, 09:06 PM
