SS braided fuel line odor
Several months ago I replaced all my rear fuel lines with new stock ones. I also replaced the front with a set up similar to that of Lindsey's SS braided kit, except I used parts from Mocal, due to the hoses running behind the brake booster.
When I put my nose against the SS braided lines, I get a fuel smell. Nothing is wet with fuel anywhere. The weird thing is, my Dad's '88 has the Lindsey kit installed and has the exact same problem. My girlfriend is complaining about the fuel smell in the garage and now she wants the car out! Help me! Anybody with the Lindsey kit or any SS lines have this fuel odor problem? Can these hoses be defective? Any help is appreciated.
1983 944 n/a 5 spd |
Toofah King Bad
I have custom SS lines on my 931, under quite a bit of pressure, and they don't smell. I also doubt the hose itself is defective. . .if there is a leak, it seems more likely to be at the crimp.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
If the smell is strong enough to make your girlfriend want the car out of the garage - you definately have a leak. It's not wet because the fuel is vaporizing and evaporating but that is the perfect condition for an explosion - you want to make this an immediate maintenance priority. Even if you have to go back to stock fuel lines until you figure it out.
The car is now parked outside until I figure this out (safety is my first priority.) I wouldn't think the hose is defective either, but the smell seems to be coming from the hose itself, away from the fittings, but I could be wrong. I assembled the hose and fittings myself and everything went together nicely.
Perhaps I just need to buy another length of hose and reassemble it. Thanks for the input.
Toofah King Bad
If you have a bad crimp, I'd imagine the fuel would travel (via capillary action) down the braiding pretty readily.
That would certainly be possible.
I just got off the phone with a tech rep. at Mocal and he explained to me that the ethanol in fuel can attack the rubber and leach out of the hose, causing the odor. Whether this is the case or not, I will not rule it out. Either way, I am going to disassemble and inspect. Might go with the teflon lined hose that Mocal supplies.
I would NOT use ethanol fuel in a 944, or ANY Porsche for that matter.
Actually, I wouldn't use it any any of my vehicles...winterbeast included.
Rick Harrison 1988 944S 17 inch Cup 2's, euro bumper conversion Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake MaxHP chipped |
Toofah King Bad
Sadly, it's mandatory here. . .that's why I updated my lines to teflon/SS.
Yeah, where I am most of the pumps state "contains up to 10% ethanol". Likely to effect the integrity of rubber hoses. Good to hear someone else having success with teflon lined hoses. Most likely I will go that route.
I recently had a SS fuel line fail -- and I could only detect the leak when the fuel line was under pressure. It failed at the hose due to some rubbing of the fuel line with other engine parts. I would definitely get that line replaced -- I went with a Rennbay fuel line as the replacement.
Joe Chen Current fleet: '93 Amethyst Violet 968 Cab "Lila" (back in the fleet!) ; '92 Cobalt Blue 968 Cab "Minjonet" - Canadian car '88 Silberossa 951S "Rosy" - garage queen ; Secret project ; '99 Ford Ranger ; '00 Kawi ZX6R Former cars: '94 Black 968 Cab "Steffi" (totaled) ![]() ![]() |
Redline Racer
Ethanol's been in the fuel for years, at least around here! Seems like they would have changed the hose in the kit to something that could withstand it. I would try to talk to them about it. Maybe they'll send some different hose or something. They didn't say anywhere the hose is not meant for ethanol blended fuels, did it?
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Not sure how long ethanol has been around this neck of the woods. Seems like I've noticed it more in the past 5 years.
As I mentioned earlier, My Dad is having the exact same problem with the SS lines in his '88. Coincidence? I don't know, but the hose is rated for gas, fuel, oil, water and air, so I assumed that ethanol/gas blend would be fine. I will call them to see if they can help me out. Thanks for all the help everyone.
ss braided line
yes! db cooper...i can smell the gas when i put my nose to the line...but it is not leaking at any juncture.....no gas is evident. when i stand above the lines, i get no fuel smell, only when i put my nose directly on the line. what was the solution? i hate to take that line out again it was a brand new ss line from lindsey racing......
Now, my garage smells of gas too, but it is coming from the tank area and not the fuel lines in the engine bay, probably from the return or vent lines above the tank, or possibly the tank itself. The tank will be coming out this winter and all lines replaced. I am planning on replacing the lines under the hood soon too, with some braided items, perhaps from Lindsey, along with new pressure regulator and seals for good measure. After my friend's 86 turbo burned in the garage where we both parked next to each other every day, I don't take gas smells very lightly! In his case, the leak was likely at the custom pressure regulator, perhaps not being tight enough. After he drove off, just before the fire started, there was a puddle of gas next to my 944... Within minutes, all he had was melted alloy, seized steel, burned fingers, and a totaled 944 turbo.
1985.5 944 NA 1972 Triumph GT6 1982 VW Westfalia 2003 F150 Supercrew 4x4 1988 F350 Regular Cab 4x4 |
newworld- I ended up replacing the ss braided rubber hoses with ss braided teflon hoses from Mocal. They require different fittings (TFE) though, so you can't just buy a length of teflon hose. Look at the online Mocal (B.A.T.) catalogue, figure out what you need and give them a call, they'll help you out.
After doing this upgrade, I no longer have any fuel smell off those lines. My Dad also replaced his Lindsey kit with teflon. It sucks to spend more money, but I can sleep at night knowing that everything is sealed up. Cheap compared to losing your car, your house or your life. ewalt98- Any kind of fuel smell should be addressed right away as your friend found out the hard way. Lots of houses with gas water heaters and furnaces in the garage. Fuel vapor and a pilot light is a bad mix.
Yep, that's why I keep constant airflow through the garage until I can get everything fixed.
![]() ![]() This is important enough to bring it to the top. Len ![]() |
Teflon lined hoses are always a must with fuel containing ethanol.
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles |
That Ethanol s**t has been forced upon us here in the US for that last 20 years. I remember when it came out in the early 90's. I've had so many issues with my small engines that I've quit using it in my bike, lawn mower, and any other small engine equipment where the fuel will sit for a few weeks if not months in the tank. Fortunately in our area we have several gas stations that sell no-ethanol gas. Why anyone would make replacement fuel lines for these cars and NOT make them with line that is ethanol compatible is beyond me.
87 944N/A since 1992 87 944S - Near Future Engine Project Car 88 944S - Current Project 84 928S - Restoration Project |
