Question Piston Scuffing
I’m in the home stretch of my timing belt failure rebuild. I have taken off the cylinder head and am cleaning the carbon deposits off the pistons. Once clean I notched some scuffing on the top. I’m unsure on what the tolerances are on these, would these work fine or are they too damaged?
Old 06-18-2017, 09:21 AM
maybe a light touch of sandpaper to smooth it down but i wouldnt worry about it.
Old 06-18-2017, 09:26 AM
Or use deburring tool on the sharp edges. Then sand the edges and edges of other valve pocket.
This improves heat dissipation and knock-resistance
Old 06-18-2017, 01:40 PM
yeah. As long as the edges are smoothed and nothing gnarly sticking up, it should be fine like the others say.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 06-19-2017, 05:25 AM
Tags
block , cylinder head , piston , rebuild , timing belt
