chefyong's Avatar
Interpreting Torque Values
Hello,
Can someone enlighten me how to interpret the following torque values.
M8 20 + 2Nm (14 +1.4 ft. lb)
M10 40 + 5Nm (29 +3.6 ft. lb)
On the first value, how does the 2Nm be applied to the 20Nm? and so with the second value, how does the 5 Nm be applied in reference to the 40Nm?
Do you torque 20 first then 2Nm? and 40 First then do 5 Nm for the second value?
Manuel
Old 09-06-2017, 03:29 PM
Bradical's Avatar
I'm not sure, but I am going to guess and see how close I can get!
I am thinking that the 14ft/lb is a lubricated torque spec, and 14ft/lb + 1.4ft/lb (15.4ft/lb) is the dry torque spec of those bolts. Don't know, but that's my guess. Those values are just general ones given for any otherwise unspecified M8 or M10 bolt on the car- obviously across a bunch of different applications. Some bolts or studs may be lubricated or not based on that.
Again, guessing!
PCA - Florida Citrus Region
Old 09-06-2017, 06:13 PM
9FF 9FF is offline
9FF's Avatar
Originally Posted by chefyong View Post
Hello,
Manuel
I'll address the M8 bolt, the "+" is the tolerance and it means you can torque between 20 to 22Nm. So it has a +10% tolerance. The M10 bolt has a range likewise of between 40 to 45Nm.
You cannot apply a torque of 5Nm to a bolt that has been previously torqued to 40Nm, it simply will not register. Things like cylinder heads usually have INCREASING torque values that you apply in sequence like you are assuming.
Hope that makes sense ��
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 09-06-2017, 06:36 PM
chefyong's Avatar
yes, now it makes sense.
Thank you for your help
Old 09-07-2017, 05:56 AM
