drkshdw's Avatar
Is this some sort of diagnostic sensor?
Digging around the engine bay in my 87 NA I found this sensor of sorts. It sits in the bellhousing directly under the speed and reference sensors. The other end is a gray wire with a 3 prong plug on it that's capped off. I've read about diagnostic sensors on the late cars, is this what this is? I don't remember it being on my other 944's but it's been years since then. What exactly does it do?
Old 10-16-2017, 01:21 PM
Yep, that was put there for use by dealer technicians (when they still used a large diagnostic machine). Dead weight now...
Good luck, George Beuselinck
Old 10-16-2017, 01:27 PM
drkshdw's Avatar
Thanks George for confirming. What do people use to block off the hole when they remove them? Or do I just cut the wires to the bell housing since the wires are coming out the back of the plug anyway? Hmmm...
Old 10-16-2017, 02:46 PM
The easy thing to do would be to cut the wires, then you would have no hole to block off.
Old 10-17-2017, 04:08 AM
