1989 S2 struts
To replace front struts in an 89 S2 requires the full assembly correct? Not just the inserts?
I just sold an 83 with koni adustables and an 86 with brand new bilstiens. My newly acquired S2 bounces all over the place and needs help!
Old 10-18-2017, 04:30 PM
In the Fires of Hell.....
kdjones2000's Avatar
Yes, or do the hacksaw Koni option.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-18-2017, 04:44 PM
Dimi 944's Avatar
2nd or I have an already converted set with new Koni inserts available for sale.
Dimi P
Flying Horse Motorsport LLC
flyinghorsemotorsport@gmail.com
Dimi Paralanov
Old 10-18-2017, 05:51 PM
Dimi P
sending pm
Old 10-18-2017, 07:40 PM
How important is it to pair the front struts with rear shocks?
Meaning koni sports in the front and say bilstiens in the back.
The koni sport rears are only adjustable if you remove them correct?
I will probably never do that and the bilstiens I believe are 20-30 bucks cheaper per side.
My 83 had koni sports front and cheapos in the back and it felt great but I am comparing that to my S2 which has blown front and rear shocks.
Old 10-20-2017, 07:29 AM
Dimi 944's Avatar
I run my S2 with Bilsteins at the rear. No issues.
Bilsteins bare a bit more durable too.
Dimi P
Dimi Paralanov
Old 10-20-2017, 07:46 AM
9FF 9FF is offline
9FF's Avatar
You usually match the shocks to the springs so it won’t make any difference using Koni up front and Bilstein at the back. In my experience you really only adjust the rear adjustable Koni’s once or twice, to experiment, and when they feel right you leave them alone. You only might need to adjust them again if you change the torsion bar spring rate, so having to remove to adjust them is not a big issue.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 10-20-2017, 07:53 AM
My understanding is there is a difference in the return damping between the various gas shocks and struts. Regarding damping on the rebound some do/ some don't have adjustments, and some no damping at all. Return damping might affect handling adn feel.
Might want to do a search on Pelican for more info. I recall several discussions about this but difficult to remember specifics...
Regards
Old 10-20-2017, 08:55 AM
Dimi 944's Avatar
Bilstein and Koni rear dampers were a factory option for the S2. Either shock will perform well for street use with stock torsion bars. I have had both on my street S2.
Dimi P
Dimi Paralanov
Old 10-20-2017, 09:39 AM
