1989 S2 struts
To replace front struts in an 89 S2 requires the full assembly correct? Not just the inserts?
I just sold an 83 with koni adustables and an 86 with brand new bilstiens. My newly acquired S2 bounces all over the place and needs help! ![]() |
In the Fires of Hell.....
Yes, or do the hacksaw Koni option.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
2nd or I have an already converted set with new Koni inserts available for sale.
Dimi P Flying Horse Motorsport LLC flyinghorsemotorsport@gmail.com
Dimi Paralanov flyinghorsemotorsport@gmail.com 1986 Porsche 944 3.0L 16V Conversion - on track duty! 1989 Porsche 944 $2 - for fun! |
sending pm |
How important is it to pair the front struts with rear shocks?
Meaning koni sports in the front and say bilstiens in the back. The koni sport rears are only adjustable if you remove them correct? I will probably never do that and the bilstiens I believe are 20-30 bucks cheaper per side. My 83 had koni sports front and cheapos in the back and it felt great but I am comparing that to my S2 which has blown front and rear shocks. |
I run my S2 with Bilsteins at the rear. No issues.
Bilsteins bare a bit more durable too. Dimi P Flying Horse Motorsport LLC flyinghorsemotorsport@gmail.com
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
My understanding is there is a difference in the return damping between the various gas shocks and struts. Regarding damping on the rebound some do/ some don't have adjustments, and some no damping at all. Return damping might affect handling adn feel.
Might want to do a search on Pelican for more info. I recall several discussions about this but difficult to remember specifics... Regards |
Bilstein and Koni rear dampers were a factory option for the S2. Either shock will perform well for street use with stock torsion bars. I have had both on my street S2.
Thread Tools | |
Rate This Thread | |
