gt350mike's Avatar
Question Alternator -Leave alone, rebuild, or Replace?
We're replacing the belts, rollers, & the water pump but I'm wondering what to do about the alternator. The car has 87k on it and it hasn't been running in two yrs. I have no idea if its working (I could take it to Auto Zone and have it tested).
Should I leave the alternator alone, rebuild, or buy new/rebuilt unit. My gut feeling is "if it ain't broke, don't mess w/it", but since its easily accessable it sure is tempting. Suggestions please!
2015 GLK (Momma's ride)
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 02-22-2003, 09:18 AM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
rebuild it.. why not?.. or replace it...
My car is naughty
Old 02-22-2003, 10:47 AM
Mike, Don't bother. Leave it as is. to quote yourself "Don't fix what ain't broken" Why spend the money if you do not have too.
Ross
'87 944S/968 conversion
Old 02-22-2003, 10:58 AM
SoCal Driver's Avatar
When you get it started check the voltage across the battery terminals.
13.8 to 14.4 volts DC says the alternator is working. 14 or better is preferred.
Seldom do the Bosch alternators die. If you do have a low charging voltage just replacing a $20 regulator in the back of it saves the $160 for a rebuilt.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-22-2003, 11:22 AM
Roger Hall's Avatar
Good advice listen SoCal.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 02-22-2003, 02:58 PM
jknapp3's Avatar
Where are you buying a regulator for $20.00 ? Best I found was $56.00 (1982 924na) The Alt was shot on mine, I converted to a 1979 Camaro alt for $51.00. Small tweaking to fit, now 14vt solid, and cheap to replace in the future.
2008 GMC Sierra
2012 GMC Terrain
2004 Mini Cooper S
1987 944 NA
1967 912 Renagade
Old 02-22-2003, 03:22 PM
I got it from IceShark!!!
He also has the adjustable regulators.
Old 02-22-2003, 03:24 PM
gt350mike's Avatar
That is why I posted my question! I'm going to check the voltage after we get it running (hopefully by the 28th).
Thanks for everyone's feedback!!!
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 02-22-2003, 07:53 PM
suck my tail pipe
Frank B's Avatar
What Socal said... "extreme Bowing and homage" to Socal
Frank B
My car is naughty
Old 02-23-2003, 01:40 PM
suck my tail pipe
Frank B's Avatar
Mike, which yellow?.. the Light yellow or the Rich yellow?..
My car is naughty
Old 02-23-2003, 01:41 PM
ae1969's Avatar
Send a message via ICQ to ae1969
I bought the battery cable setup from Iceshark over on the other board...........
All I can say is WOW.
It comes with the adjustable voltage regulator, larger cables, extra ground cables............all I can say very impressive...
Changing the regulator would be a great idea...the brushes on mine were worn almost to the metal contacts (original alternator)...I would normally get 13.5 volts from the alternator....I am hoping to pull at least 14 volts out of it now..
Also bought the light update kit as well........
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-23-2003, 01:57 PM
gt350mike's Avatar
Frank B
SoCal has helped me more than I care to admit! He has as well as other on this board have been a GREAT source of info!!! We should have the car running by the end of the week. When that happens, I'm buying a round of drinks for everyone!
NOTE/DISCLAIMER: The term "everyone" regards those members who happen to be in Huntsville the day that we 944 transitions from WIP (work in progress) to FMC (Fully Mission Capable)!
BTW, It is Summer Yellow, so I'm guessing that its a light or soft yellow. Ross T and I have discussed this in detail and I think its a yellow vs biege. I'll post a pic later.
M
2016 F-250
2001 BMW M5
65 CSX 427 Roadster
Old 02-23-2003, 07:00 PM
