944 S2
944 S2's Avatar
Identifying the AC compressor
Do I need to remove the compressor to identify the specific Denso model? I’d like to look at a reseal kits from Century or Griffiths.
Anyone with a reseal experience?
Old 05-25-2018, 03:42 PM
944 S2
944 S2's Avatar
Sorry I meant to mention it’s 91 S2!
Old 05-25-2018, 04:01 PM
Just thinking out loud
mattdavis11's Avatar
10P15E. Might as well replace the nose bearing too. I've resealed several.
91 FJ80
84 Ram Charger (now gone)
Old 05-25-2018, 04:57 PM
Pauld_94S2's Avatar
Griffiths has the correct kit for the compressor, but you can call them after extracting the compressor from its hiding place and verify it. Actually the S2 is the easiest compressor to get to, its the turbo that's a killer. You may need to remove the S2 AFM for more working space, but that's all.
Also, check the high pressure side hose from the compressor to the condensor; they are the most stressed hose and will fail.
Old 05-25-2018, 07:05 PM
