New 1985 928 project - lighting help?
Hi folks, new member here, just acquired this project but grew up with my dad's 1979 Euro-spec and have had a 944 and a 911 in the past, so may be somewhat aware of what I'm getting myself into. Or not. Car was in a field for 3 years but is mechanically sound. Electrics and body need work. First issue is that most but not all of the lights seem to be out. Yes, it could be bulbs, but I'm thinking more likely a relay? or relays? given that the signals and flashers work, and a couple of parking lights come on, but no brake lights, headlights or driving/fog lights. Headlights do pop up nicely, and appear to be new halogen lenses, so presuming the bulbs inside are probably OK. Not sure about backup lights... (PO had done a lot of work on it before he parked it - fluids are pristine, new rack, new radiator, new timing belt, new water pump...) Also, while I am at it, any reason not to replace as many bulbs as possible with LEDs, and if so any guidance anywhere on which LED sizes replace which bulbs? Thanks in advance for anyone "shedding some light"!
Zac Moretz
1985 928S auto project, indishrot; 1993 Miata manual one owner; 1999 LandCruiser
Formerly: 1984 911 factory turbo-look coupe manual, guards; 1985.5 944 manual, champagne metallic; 1979 928 Euro auto, petroblau metalic (dad’s car when I was in high school); 1995 M3 manual; 1986 M6 manual
Old 03-15-2022, 09:26 AM
GUMBALL's Avatar
Couple of information sites:
Theo's 928 S4 - GT - GTS website
Porsche 928 Maintenance Tips and Procedures
Very helpful
Old 03-20-2022, 11:02 AM
Thank you @gumball!
Zac Moretz
Old 03-26-2022, 11:32 AM
Network Native
Danglerb's Avatar
I would start with cleaning all of the fuse contacts, wiggle all the relays while spraying with contact cleaner, and do the normal ground service.
Maybe buy the latest best version of a loadpro or power probe. You are going to need the tricks they can do, measure voltage at any point with a slight load so enough current flows to show weak (high resistance) connections in the circuit, apply either ground or power to the probe tip.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 03-29-2022, 10:38 PM
harborman's Avatar
Absolutely! You need to pull all the fuses and relays and spray contacts with Deoxit or CRC contact cleaner. Remove and clean all grounds. Check battery ground strap to frame. Check and clean ground to motor. I had to replace my ground strap on the battery (internal resistance).
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 04-05-2022, 06:44 AM
Thank you! I have wiggled/checked all the fuses, but have not done the relay service you suggest. I will try that. Also, as a follow up, I replaced the headlight relay and now they work, but still no other lights working EXCEPT the turn signals. That seems odd….
Zac Moretz
Old 04-16-2022, 05:11 AM
stepson's Avatar
No warning lights work? At All?
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 04-18-2022, 01:37 PM
Tags
leds , lighting , lights
