Running rich (smell rich)
Hi all fellow Pelicans,
![]() My Porsche 928 S2 from 1985, is running pretty stable in IDLE and in general seems to run also fine when driving around. But there’s a smell behind the car (coming from the exhaust) that it seems to be running rich. And if a friend is driving behind me in his car, he’ll typical when we stop and talk say “your car smell like an environmental hazard”. :-/ So it seems the problem is there also not only running in IDLE. Does any one know of a “checklist” of stuff to walkthrough for finding root cause of such a problem? I did already change spark plugs, ignition caps/rotors, air filter, engine oil, water pump, timing belt, coolant. Thx in advance. BR Chris |
Maybe some things to check would be the MAF, O2 sensor, Maybe the Ignition module. They make a special cleaner for the MAF.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Hi,
Thx for the answer harborman, I appreciate it. I’ve tried cleaning the MAF with break cleaner, I wasn’t aware there was a special clear? Where do I get that? Regarding the Ignition module, I haven’t looked at that actually, what do you recommend I do to investigate that? O2 sensor, I don’t think mine car have a O2 sensor, I’ve looked at the x-cross section of the exhaust and there’s no O2 sensor to see. Unless I look the wrong place? |
Harborman,
S2s don't typically have O2 sensors. None of my 3 have them. Definitely agree with the checking the simple things first.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Many O2 sensors listed for the 928. But maybe the S2 is different. I have the 86 928S and it shows an O2 listed for my motor. It is a key component in checking air/fuel ratio.
The S2 IS different. I've never heard of an S2 with an O2 sensor, but of course I could be wrong. I've just never heard of one or seen one with an O2 sensor
Kool
Does your car have the cat on it? Has it been gutted, maybe by a PO?
My 82 stinks to high heaven, but she has no cat.....
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
Hi again,
Sry for a few days silence on my side. Been alittle unexpectedly busy. Mine for sure dont have cat anymore, I replaced it with x-pipe instead. There was no O2 sensor. And the car was running rich beforeI did this exhaust change, so shouldn’t be the reason of the “running rich” problems. Maybe the O2 sensor came in 1986, if your car, Harborman, has an O2 sensor? |
Thread Tools | |
Rate This Thread | |
