RadioDjKev's Avatar
Send a message via AIM to RadioDjKev Send a message via Yahoo to RadioDjKev
78 928 loud sqreeching noise then motor quits Help
While on my 2nd test drive my 78' Porsche 928 quit running. As I went hard on the gas a loud Sqreeching noise(somthing very high spun occured and the motor quit. It turns over fine and everything looks normal. However I do Not think I hear the fuel pump making it's normal sound when I turn on the ignition key. I should not have got on it because there was only 2 or 3 gallons of gas in it, as that can stress out the fuel pump.
Has anyone herd this hign spun bearing sqreech sound before??
How can I fix this?
Kevin
www.KevinGerard.com
2005 Husqvarna TC250
1999 Porsche 986 Boxster 5 speed manual 90k. (as of April 2008)
Old 07-26-2007, 11:21 AM
Network Native
Danglerb's Avatar
When you get to the bottom of the tank sometimes debris in the tank can get sucked in. Start with the fuse, then the relay, then the pump itself. Two failures I have heard of beside just dead is that pump impeller comes loose, and something gets stuck in the pump. Sometimes reversing the leads to the pump and running it backwards will clear the junk. If its junk, I would flush the tank out.
On my car the loud screech happens when I get the bill.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 07-26-2007, 11:41 AM
RadioDjKev's Avatar
Just confirmed I have a broken timing belt.
I have not checked on the price of a belt yet,
When I get it all apart I suspect a bad tensioner pully bearing?
www.KevinGerard.com
Old 07-26-2007, 12:57 PM
Network Native
Danglerb's Avatar
The belt is nothing, like $35 from many sources, why it broke shouldn't be too bad either once you get it sorted out. Personally I would assume that anything the previous owner touched is suspect and should checked and/or replaced.
Pelican has it for $30 shipped free.
928-105-157-00-M21 Timing Belt, 928 (1978-82) Brand: Contitech
Old 07-26-2007, 03:03 PM
RadioDjKev's Avatar
It's my oil pump. A tiny peice of a broken bolt had fallin into the oil pan. (I was not told about this when I bought the car). I was told it just had an oil change.
So I did my helicoil repair and put it all back together.
(I was also told that the timing belt was never moved), but as it turned out it was moved 90 degress off on the right side.
Even though I bought the car like this I think it is my fault.
1st I should have changed the oil no matter what.
2nd I should have checked the timing belt marks.
I was in a hurry.. Well now I am Not in a hurry.
Thank you for your help.
Now I gotta get that flywheel pulley off?? and buy some parts.
Kevin
www.KevinGerard.com
Old 07-26-2007, 08:12 PM
Hey! Nice Rack! "Celette"
rich's Avatar
I just read your post. I had a simaler thing happen with the pump. I lucked out and just needed to replace the belt. Some times valves bend and your wallet will be the next thing to squeal!
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 07-29-2007, 08:10 PM
RadioDjKev's Avatar
RadioDjKev Update
Well I finally got it all worked out with an oil pump, timing belt, and tune-up.
Also cleaned out oil pan. The car runs great!
www.KevinGerard.com
Old 07-31-2007, 07:47 PM
