Question Side Marker Bulb Replacement
I have a 90 GT that needs a side marker bulb replaced. It seems to be the only bulb on the car that is not referenced in the owners manual. Its the right rear one and it appears that the only way to get at it is to remove the entire fixture from in side the wheel well? Or, does the lens pop off?
Thanks all!
Old 02-24-2008, 05:20 PM
chuck z's Avatar
the lens does not pop off. The easiest way is to take the fender liner out.
Chuck Z
1990 928 GT - Blk w/silk grey/black
1992 968 Cabriolet - Amethyst w/magenta/light gray
1989 944 S2 - Guards Red w/Black
928 OC Charter Member
Old 02-24-2008, 05:32 PM
Thanks!
Old 02-24-2008, 07:17 PM
Sharkaholic
Have you considered upgrading to LEDs? Those last a lot longer.
You could also replace the markers with clear ones, if you like. You can get those with black or white housings, depening on what goes better with the color of your 928.
1991 928 S4, slate grey / classic grey, slightly enhanced...
www.hookedoncars.com
Old 03-01-2008, 12:38 AM
