Just saw this for the first time... Boy there sure was a lot of white smoke coming out of that tail pipe. How old are those head gaskets? Would hate to see all that hard work get destroyed...
![]() Quote:
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos) |
Banned
I really don't understand how the lot of you don't like this guy and his accomplishments. I can semi-understand the debate between types of superchargers. Should it be a centrifugal-flow, a twin screw... or maybe a turbocharger? It is all the same, forced induction. All of us have significant others, and they in the end are the primary determinant in what we do with our toys, our Porsche 928's.
Why the acrimony toward Herr Kuhn and his latest turbo system? N! |
Heavy Metal Relocator
who knows...it certainly isn't justified.
for a while there, I thought it was a sand box issue.....maybe some folks (not referring to John here) just can't have any critiques sent their way, but John has been pretty much over it for some time now....... the complainers of what I have written in the past are the same ones who don't follow the rules per se, and then when someone makes a comment (about whatever), the response is "you don't know what you're talking about...." Unjustified as well- if we all would just quit teasing, trashing, bashing and just plain stopped being mean to each other, the forums would be a lot better off>>>>>>>>> all of this picking at each other has become very tiresome........ ![]() |
Andrew, I do take it that you understand that one of the by-products of combustion is water vapor...
I'm convinced all the problems you have had as of late are caused by Bad Kharma. Other than that I really don't have anything else to say here.
Kuhn Performance Technologies, LLC Big Gun: 1988 928S4 Twin Turbo, 5-SPD/LSD 572 RWHP, 579 RW ft-lbs, 12 psig manifold pressure. Stock Internals, 93 octane. Little Gun: 1981 928 Competition Package Twin Turbo, 375 RWHP, 415 RW ft-lbs, 10psig manifold pressure. Nikasil Block, JE2618 Pistons, 93 octane. Last edited by Herr-Kuhn; 04-21-2008 at 03:41 AM.. |
Hey! Nice Rack! "Celette"
Cool car! What a lot of real work! Hat's off to you!
Early Alien Sightings 914-M28/11 5.0 Hybrid (The Alien Sharkster) I think I smell your blood in the water WCC 04 done by the kids Who says Aliens only abduct people. |
I had an issue with pitting on my head which allowed coolant to ever so slightly leak into my combustion chamber. I would hate to see something similar happen to this car. If that car was cold, I could understand the white smoke as a result of accumulated condensation burning off, but once warm it shouldn't expell that much except in the coldest of climates (e.g. Minnesota), and even then it shouldn't be that much. Hence my concern. A simple explanation like "The car was was not fully warmed..." or "the HGs have already been replaced" or something of the like would have been a more appropriate response than an attack on me. I love fast cars, no matter how it's accomplished - be it displacement, supercharger, turbo, NOS. Just saw a 650WHP Mitsubishi with a 2.3l engine running 30 psi. Simply amazing. Maybe someday I can get to that type of HP/L, but that's a dream for now. I digress. We need to all work together and share information that we gain through our efforts to lessen the learning curve. It's kind of like that analogy of working together to grow the pie, rather than just trying to get the largest slice. By growing the pie we all win. It's a much more mature attitude. For example I learned how to strengthen our stock TT shafts by 50%. I'm happy to share the information once this BS stops. Quote:
I'd be happy to buy you a beer sometime if you'd let me and maybe we can bury the hatchet. What do you say? |
Trust me Andrew, there are no issues from my side. We just want to surround you with turbo technology until you say "Uncle"
![]() We were going to dress "Sonett III" up in a Monkey suit and let him chase you around the show in June whilst carrying a turbocharger, but on closer examination I determined this would not be in good taste and that someone may end up taking offense to it all. You buy the beer and I'm game, but I won't be throwing a blown head gasket into your shrine as I don't have any to submit!
Kuhn Performance Technologies, LLC Big Gun: 1988 928S4 Twin Turbo, 5-SPD/LSD 572 RWHP, 579 RW ft-lbs, 12 psig manifold pressure. Stock Internals, 93 octane. Little Gun: 1981 928 Competition Package Twin Turbo, 375 RWHP, 415 RW ft-lbs, 10psig manifold pressure. Nikasil Block, JE2618 Pistons, 93 octane. |
Well then I guess you need to stop the BS Olson.
interesting......haven't heard of anyone breaking a torque tube (shaft). I've seen the couplers broken, clutches blown, transmissions torn up......and oiling problems with the engines, but no shaft breakage. maybe.....it's the next thing in line for failure....? |
No BS from me...
![]() Quote:
The solution is heat treating. The factory TT's are not heat treated. The issue is that traditional heat treating (horizontal) will cause the the shaft to bend/warp which will cause considerable vibration at 6800 RPM. If you can hang it and heat treat it, you can impart 50% more strength to the shaft and gravity with help you to keep it straight. But it's not easy to find a place to do it. Luckily the breaks appear to have been anomolies thus far, but eventually it will become an issue for high HP 928's. |
HA HA HA . That is very funny coming from you[ the one that starts all the BS] Olson. That goes to show people how much of a man that you realy are. Besides, I am not going to go on with this game that you are playing. That's the way I see It olson.
when you look into the expense of it, and then match the cost of replacement to it, you might find it's not worth the effort...... I've got two complete torque tubes w/ good bearings in my pile of parts, and no takers. in this case I suspect it's just easier/less expensive to do a changeout of the whole tt assembly. --------- |
A Wrench
Maybe i should try that before I blow another one.
'88 Supercharged and lots of other fun stuff. |
I have been following John and his progress for years. I saw the car at SITM last year and it is spectacular. His work is outstanding! I look forward to seeing his car again this year.
Glenn
87 928 - AT, Strosek Ultra Wide Body Kit Black/Burgundy :jumper: 88 928 - AT, RMB, AutoThority Chips, GTS C1 Rims Metallic Silver/Black |
Stop by Glenn...we can go for a ride. I didn't give any rides last year.
John,
That would be great, I will take you up on it! Glenn
Edit: Nope! no ignore list. Oh well. I guess I will just have to taunt you a second time... ![]() Last edited by AOlson; 04-22-2008 at 05:19 AM.. |
Network Native
Isn't the answer in the Porsche owner FAQ?
![]() ![]() Use the "manual" ignore function, pay no attention to negative off topic comments and say what you want to say. BTW I have a Kentucky long rifle with a barrel drilled by hand over 100 years ago, I sure hope mechanic skills haven't dropped that much since then. OTOH I am not really buying the drill a hole and make it stronger stuff. Besides axles will break before the TT does. |
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos) Last edited by sonett3; 04-22-2008 at 11:37 AM.. |
