S4hounddog's Avatar
928S4 Heater problems
Hi Guys,
I'm having a problem with the heater A/C system in my '88 S4. It blows hot air even with the A/Con and it doesn't change no matter what the control positions are. I've replaced the heater valve (old one was sticking) but the system still blows hot air.
Any suggestions?
Old 04-06-2008, 07:24 AM
S4hounddog's Avatar
The slider postions seem to work properly but I'll check that first. It may be the vacuum pod as you suggest so I'll be using a vacuum pump to check the system today.
I'll post the outcome.
Thanks for the input.
Old 04-06-2008, 08:36 AM
