| Registered Join Date: Dec 2007 Location: Vancouver, b.c.
				928S4 Heater problems
			Hi Guys, I'm having a problem with the heater A/C system in my '88 S4. It blows hot air even with the A/Con and it doesn't change no matter what the control positions are. I've replaced the heater valve (old one was sticking) but the system still blows hot air. Any suggestions? | ||
|  04-06-2008, 06:24 AM |
			The slider postions seem to work properly but I'll check that first. It may be the vacuum pod as you suggest so I'll be using a vacuum pump to check the system today. I'll post the outcome. Thanks for the input. | ||
|  04-06-2008, 07:36 AM |
