Hey! Nice Rack! "Celette"
rich's Avatar
I need a K jet part... anyone?
I need a fuel temp switch. It's a two wire warp switch. It is closed when cold. When hot it opens and disconnects the ground. It's located on the passenger side of the engine on top of the heater hose connection. The attached photo shows the broken switch. one of the male connections broke off.
Anyone have an extra?
It turns this hot start solenoid off which turns off the fuel to the cold start injector.
I did a work around and used a water based switch but I would like to put this back the way it is supposed to be.
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 10-28-2008, 08:36 PM
Network Native
Danglerb's Avatar
More info here, and they call it a "temperature time switch".
http://928.jorj7.com/icu.html
Pelican sells it for $57 shipped, but the connector is like an injector.
928 605 101 00
http://www.pelicanparts.com/catalog/shopcart/928M/POR_928M_WATmis_pg1.htm
Old 10-28-2008, 09:02 PM
rich's Avatar
928 605 101 00
Thanks for the link buddy. The work around I used incorperated the type of sensor shown on the pelican parts page. That sensor needs to sit in water. The one I'm looking for is dead headed in the heater core connection on the rear of the right cylinder head. The threaded hole does not actually read direct water temp, but is a heat sink and reads the radiated temp from the engine.
Old 10-29-2008, 06:23 AM
Network Native
Danglerb's Avatar
Need picture, and refresh my memory on exactly which model year this part is from.
The location you talk about I am used to seeing a thermal valve for the air pump vacuum control line.
Old 10-29-2008, 09:21 AM
rich's Avatar
1980 M 28/11 4.7 euro "S" No lamda.
I attached a photo in the above post. Here's the switch. It's supposed to have two mail terminals.
Old 10-29-2008, 02:44 PM
Arrgh Matey!
chesireIsugaree's Avatar
I have an 82 if it helps you... If the part is not broken and I have it, $20 plus shipping and it's yours.
Mason
'90 Gt Black/Black 90k
Old 10-29-2008, 04:39 PM
rich's Avatar
I'm not sure the 82 has this. Check and see. If you have it, pm me you paypal address and shipping to 55803
Old 10-29-2008, 05:15 PM
Network Native
Danglerb's Avatar
I meant picture of where it goes ...
BTW with your cams its actually a M28/10.3
Old 10-29-2008, 08:42 PM
rich's Avatar
It's on the heater hose fitting. Your part would have a tube coming off of it. I didn't need the tube so I cut it off and capped it with a brass fitting.
Notice one of the terminals is broke off.
You can see it to the left in this photo under the fuel line.
Old 10-29-2008, 09:17 PM
