BLK87S4's Avatar
Unhappy Same (injector) song, verse 3
Okay, I'm a moron. I haven't fixed my injector issue at all. At first I thought it was a poor relay connection. So I cleaned out the relay connection (it was very corroded). Next time I took the relay/fuse panel out and cleaned off all the corrosion. Now I'm stuck. When I turn the key to "run" the injectors start chattering/clicking and the car will not start. In the past I could let the key remain in the run position and the relays would eventually stop clicking and the car would start. Well this time I've left the key in the run position much longer than in the past and they are still firing away. The car will not start and I've checked all of the system connections (for a poor connection) to no avail. Any pointers you all can provide would be appreciated.
Thanks,
Robert
Old 01-31-2009, 02:11 PM
Network Native
Danglerb's Avatar
Chattering injectors, classic sign of LH failure. Sorry dude, but I think your going to need a rebuild. Roger I believe stocks JDS rebuilt units and can do a quick exchange.
Old 01-31-2009, 03:13 PM
