MPDano's Avatar
Red Door Jamb Lights? Always ON???
I just replaced my rusted door jamb lights (Red). They are on all the time. I tried to push the door switch on both sides but they stay on. Anything else controlling these that I can check?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-01-2009, 03:32 PM
seems I remember reading s/w that this is typical when the switch or wiring goes bad. I'll see if I can dig it up, b/c there was a fix procedure as a bonus.
Chris
86.5 928 Indy Red/Black, A/T, 118,456 miles and counting
Old 03-01-2009, 04:25 PM
sort through this - http://http://forums.rennlist.com/rennforums/928-forum/434308-light-that-never-goes-off.html
was not the info I was thinking of, but may point you in the right direction.
HTH
Chris
Old 03-01-2009, 04:32 PM
MPDano's Avatar
Thanks Chris! Weird, took a quick drive around the neighborhood and they are now off. I don't have enough time to check if they will work as intended, but will check later tonight. Gotta go do errands.
Old 03-01-2009, 04:59 PM
MPDano's Avatar
Question? When do the Red Door Jamb Lights supposed to turn on?
Old 03-01-2009, 07:27 PM
Banned
Normy's Avatar
When the door opens. They are designed to alert drivers to an open door when you are parallel parked. Most European cars have them.
N
Old 03-02-2009, 06:42 AM
Network Native
Danglerb's Avatar
Square lights in the doors are on my short list for converting to LED.
Also on my short list are finding some excellent quality pin switches that would work in the doors, maybe a reed or something sealed.
Old 03-02-2009, 10:30 AM
They go on with the other interior lights.
Check that the rear hatch is fully engaged. If the hatch part that goes down into the receiver is not down far enough to hit the switch at the bottom, it will leave those lights on.
I think this is one of the most common causes of battery drain in the 928.
It was happening on mine and two other 928s I had in the shop last year.
1993 928 GTS
2012 Porsche Cayenne Turbo
Old 03-03-2009, 07:49 AM
