1982 928 us
vacuum hose 1/8qty 3/16qty
would you say 5-6 ft of both is enough would i be too close its too much or would need more followed danglerb here there and everywhere routing post about how much is used just replacing need no T or rerouting
meaning smallest and next size up the measurements could be metric but i measured fraction
Old 04-20-2009, 12:46 PM
Network Native
Danglerb's Avatar
I bought a kit from Roger, as well as some silicone tubing from another vendor, used the kit from Roger with just a couple short lengths of the silicone tubing as needed.
Roger's kit uses Mercedes fittings for 90 degree, T, etc. one Porsche multilegged thing, and the rest is thin nylon hardline. I think its the better way to go, looks factory, installs easy.
Old 04-20-2009, 12:53 PM
MPDano's Avatar
Also Carl has a Silicone Vacuum Line kit, but I kinda cheated and used his measurements and bought the tubing elsewhere. There are lot's of different sizes of vacuum lines, so one size isn't going to cover all lines.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-20-2009, 01:18 PM
MPDano's Avatar
Old 04-20-2009, 01:21 PM
MPDano's Avatar
Here's the sizes you will need
10 ft of 3mm silicone hose
5 ft of 6mm silicone hose
2 ft of 10mm silicone hose
Old 04-20-2009, 01:27 PM
'79 928 Euro 5 Speed
Rupesy's Avatar
vacuum lines
On that note, I bought a bunch of vacuum lines at autozone just to get me going with the idea that I would look around for something better when I had more time. The autozone ones don't feel like they can hold up to a lot of heat and vacuum but seem to be doing the job for now. I haven't necessarily noticed any issues at this point but think they could be collapsing at certain times. I'm guessing the silicone ones are much more durable?????
BTW, I like the blue accent.
Old 04-21-2009, 04:14 AM
MPDano's Avatar
Yeah, the Silicones are pretty thick. It would be very difficult to collapse them. They come in all colors, so you can go Black if you want the stock look.
Old 04-21-2009, 06:02 AM
Network Native
Danglerb's Avatar
Factory used hard lines and rubber bends and couplers, its just a much cleaner install IMHO.
Question you might want to ask yourself is how would you know if the vacuum lines were collapsing or flowing much less than desired?
Old 04-21-2009, 12:34 PM
1982 928 us
thanks got er done inch by inch for footer by footer job.
just to note had i know colors mmm would have got purple
just straight up blk
Old 04-25-2009, 12:47 PM
