Door panel bolt connector plastic
My 88 has broken plastic tabs (door panel) where the three bolts connect it to the door. All three have cracked and broken from age. As I looked at it, I wondered if I could re-enforce it with a piece of plastic from a milk bottle with some super glue. Anybody out there have a good solution that last?
Old 04-30-2009, 09:41 AM
MPDano's Avatar
You could probably rivet a thin piece of metal and then make a hole in the metal the same size as the bolt. I wouldn't mess with glue or plastic in this area, the bolts will pull your panel towards the door.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-30-2009, 09:46 AM
s928s's Avatar
Find "ROB BUDD" here or on rennlist. he sells a pre-cut metal repair panel.
look for the " 928 leather shop "
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 04-30-2009, 10:21 AM
Network Native
Danglerb's Avatar
I "think" the source of the aluminum panel reinforcement is Australia, and a couple vendors sell it.
Best fix, get a nice unbroken plastic part, and put the reinforcement panel on before it breaks.
Old 04-30-2009, 11:33 AM
Not sure I understand. do you mean to reinforce the existing panel with plastic and then re-install?
Old 04-30-2009, 12:46 PM
MPDano's Avatar
Nah, it fits in the door panel/arm rest I believe and reinforces it. Heres a pic.
928 Armrest Backing Support Bracket Set
Made of steel. Adds structure and support to the plastic and often broken 928 armrests. Two are included in this set along with mounting screws and washers.
$79 at 928LeatherShop
Old 04-30-2009, 01:11 PM
Network Native
Danglerb's Avatar
http://www.mailordercentral.com/928intl/prodinfo.asp?number=ARMREST
Maybe different, $85 a pair from 928Intl.
Old 04-30-2009, 02:24 PM
Thanks!!!
Gotcha, thanks!
The door armrest support brackets all come from the same source.
1993 928 GTS
2012 Porsche Cayenne Turbo
Old 05-01-2009, 05:01 AM
