Question No Spark
After driving my 82 928 with 95,000 miles on a hot day it would not start. the motor cranked and smelled like it was flooded. after coaxing it to run i let it idle for five minutes and drove it to the shop. car started fine after i pulled in until i let it sit for 20 minutes when it would not start again. after investigating the car has no spark. any suggestions on where to diagnose this? i was told it was the capacitor distributor box (cd) is there any way to test this theory? could it be distributor, coil, wiring problems etc... and if so what are the possibilities of failure and how do i test them. Thanks guys
Old 06-30-2009, 01:14 PM
Petie3rd
Mrmerlin's Avatar
most probable cause is the green wire that goes from the box to the distributor, at this point you can check the connectors, also check the coil wire to the dist cap remove it and verify both ends are clean and that the wire itself isnt grounding
Old 06-30-2009, 08:09 PM
Network Native
Danglerb's Avatar
+1 on the green wire.
Shop suggesting the CD ignition is a problem, well thats a red flag the shop doesn't know the 928, the early ignition boxes almost never fail and a bad green wire is common.
Old 06-30-2009, 09:48 PM
MPDano's Avatar
Here's my write up and pics of the Green Wire Replacement too.
http://www.porsche928forums.com/viewtopic.php?f=9&t=4&p=1871&hilit=green+wire#p1871
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 07-01-2009, 06:00 AM
MPDano's Avatar
Old 07-01-2009, 06:01 AM
Thanks guys replaced wire fired right up
Old 07-02-2009, 08:40 PM
MPDano's Avatar
Green Wire?
Old 07-02-2009, 08:47 PM
Petie3rd
Mrmerlin's Avatar
since no other wire was suggested , i would guess that the green wire was in fact replaced, but this could also mean an ignition wire , or a ground wire or any wire for that matter, so we are left to guess?/????????
Old 07-03-2009, 05:52 AM
Network Native
Danglerb's Avatar
The Green Wire claims victory in the absence of all others.
Old 07-03-2009, 08:52 AM
