center console help, take a part procedures wanted
Hello My fellow 928 owners,
I need to replace my a/c switch that is connected with the central warning light and central locking switch/light, the question is what is the easiest way to get that section of the console apart enough to change out the switch and wiring harness? - if you have photo's that would be great, or if you can direct me to a site that spells out the procedure that would me most helpful, thank you to all that respond - Tom |
you need to tell us what year it is....some are easy to do...early cars are a pain in the a$$...
John ......... 1978 Porsche 928 5sp LSD 1982 porsche 928 5sp LSD |
Sorry everyone, its a 1988s4
1. remove the right side parcel shelf. 2 10mm at each front corner and 2 10mm at the bottom of the glovebox ( warning conector is runs along the r/s harness.)
2. remove the right side console panel, 2 phillips head screws 3. remove the trim around the shifter and radio and upper console 4.. remove the 2 phillips for the central warning panel, disconnect flat connectors from underneath, may be easier to access by moving the radio up slightly. panel will pull straight out of the center console. I hope this helps.
autowerks9 PCA SINCE 1991, REISENTOTER 1982 EURO 928S 320HP MEDIORMETALIC/BURG. 1987 944S- GT3 BODY CONVErSION RED/BLACK( sold ) 2003 MERCEDES E500 Sport "Einfarbig" |
Porsche newbie
On my 87, only step 4 in David's write up is applicable. There is a black trim piece that goes around the ventilation control module, the central door lock manual and the radio ending at the clock. To remove that bezel, we had to remove the upper central vent. It just pulled out, but two of plastic retaining pins were broken. You will probably need to remove your radio too.
With the central vent removed, You can work the black bezel out. Dr. Bob has a write up of that process in his A/C relay replacement write-up. "The center vent pulls straight out to remove. The trim bezel surrounding the controller and switch panel below it also pulls in, up and out. It is not necessary to do any disassembly of the console except from the front as described." You may need a helper to pull the center console edges outward since the they cover that trim piece/bezel. After the black bezel is removed, I had access to the central lock console retaining screws.
87 928 S4 Exported for Japan |
thanks for all the input, now I just need to get motivated and change out the part - Tom
Petie3rd
Once you have pulled out the central air grill, then with a thin screwdriver gently pry one side of the H cover ( this part surrounds the HVAC and goes down to the radio) as you push on the inside edge of the console , once its out a bit then slide it up about a 1/4 in. then work it off the console.
To swap out the AC part you will also need to remove the screws for the HVAC head unit this part needs to slide out of the console a bit but it doesnt have to be disconnected. Once you have the 6 screws out then the AC portion will disengage from the HVAC part and can be slide out to disconnect the black plug and the 2 wire harness plugs previously mentioned in the other post. Refit the 6 screws with a magnetic screwdriver so you dont drop the washers into the radio. Then the H trim slides back into place , make sure the HVAC and the AC panels are centered.
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
thanks Mrmerlin,
thats sounds easier than I thought, thanks for the tips, I will get on it soon - Tom |
