Shift coupler
Hi Guys
I have noticed that my Shift Coupler is missing the rubber ring of one of its sides (as can be seen in the attached picture) which causing the shift rod to act in a weired way while changing gears.
I found this part (92842402900) but I dont need the entire part...only one rubber ring.
Do you know where I can find such a ring? maybe it has a catalog number that I can use?
I dont want to buy the entire Shift Coupler just because of one rubber ring...
Porsche 928S 4.7L 1980 European redhead
Old 08-21-2009, 07:13 AM
rjm65's Avatar
http://www.porsche928forums.com/viewtopic.php?f=2&t=445
Old 08-21-2009, 08:38 AM
Thanks!!!
Old 08-21-2009, 09:51 AM
one more question...does anybody knows the diamiter of the rubber bushing? (outside and inside)
I might find something like this also in my country instead of ordering it from the US...
Old 08-21-2009, 10:07 AM
rjm65's Avatar
Here's the specs for the bushings I used:
Dorman Motormite 31016 Suspension, Shock Mounting Hardware Features:
• Shock Mounting Hardware
• Make: Ford 1965 and newer
• Size: .400" I.D. x .996" O.D. x .556"
I also saw some generic polyurethane sway bar bushings that could be easily modified to fit, but those would not insulate vibration very well.
Old 08-22-2009, 07:59 AM
ice-hot's Avatar
Or you could get the right ones for $5.00 here.
https://www.928gt.com/skin2.htm
John
"Por ' sche" is a two syllable word.
"79" US
Old 08-22-2009, 08:44 AM
Xlot's Avatar
John
Yep, thats what I did.
The actual part is this:
https://www.928gt.com/ps-181-97-5-speed-shift-rod-coupler-bushing-77-95.aspx
The bushings from 928 Specialists were approx. 1mm thicker each than the originals, and reduced the shifter side-to-side slop to pretty much nil. I've done this on both my cars - one has a short shifter and one is stock, and the difference in both cases was huge.
Various manual S4's
Old 08-22-2009, 04:41 PM
rjm65's Avatar
OP is in Israel, he was looking for something generic that he could make work.
The shock bushings I found were $3 at Pep Boys (pack of 2), and was roadworthy again that same Sunday afternoon.
Old 08-22-2009, 08:16 PM
MPDano's Avatar
Sell it and get an Automatic, issue resolved
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-22-2009, 09:36 PM
Xlot's Avatar
Amazingly, Porsche centers and independent workshops all over the world use the same part numbers
Yoni, give the parts desk at your nearest Porsche center a call and see how much the bushings are (part # 911 424 223 03) - if they're $5 at US specialists, then expect to pay a little more, however small plastic parts are usually not hugely more expensive in my experience.
http://www.porsche.co.il/
Various manual S4's
Old 08-23-2009, 03:49 AM
wow guys, thanks a lot for that information!!! I will call Porsche center here and see how much it can cost.
Old 08-23-2009, 05:32 AM
Are you sure that this is the correct part number? I just called to Porsche center and I have been told that there is no such part...at least in their computer...
Old 08-23-2009, 06:54 AM
rjm65's Avatar
Hope this helps, here's the link to the bushing on Pelican with the full part#:
911-424-223-03-M260
Old 08-23-2009, 08:14 AM
Thank you...strangly, they dont have this item I guess I will order it from Palican.
Old 08-23-2009, 02:13 PM
