Recovering dismantler
So, I got the new steering bearing and ignition electrical switch installed, etc - and now for the next issue.
When i turn the key I can hear the heat/ac controls going through their cycle in the dash area, but the vent control in the top center of the console is in the closed position, and will not open under any position of the heat/ac control - I think it did before i replaced the bearing, but i am not sure and don't see a relationship, I checked all the air lines to the controls while i had the pod pulled to replace the switch. I pulled the vacuum line at the heater valve at the rear of the engine compartment, and it is working fine, holds vacuum and with a vac Gage in line it shows 18 Inches of vacuum at idle, and it is shut hard. This is one of the few areas I have not dived into, so can someone give me some steps to test the control? TIA
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
Petie3rd
go to 928gt.com
find page 2 then go to tips and links click on Wallys HVAC system, it will give you ways to diagnose and fix your HVAC system
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
I have Wally's great document, I was looking for a seen this before try this :-)
Petie3rd
I have seen this before so try this.
Read Wallys HVAC document then you will know where to start looking for your problems. If you follow Wallys info it will take you to the right places to look
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats Last edited by Mrmerlin; 10-08-2009 at 05:48 PM.. |
Petie3rd
this is a lot easier than trying to re write what Wally has already written
will do, thanks
