redstormcoach's Avatar
Whats it worth? 1985 928s 32v with PPI results
I am trying to find out the value of a car I saw for sale in FLORIDA. Is there a website/source that can give me Book Value?
Here is what I know.
1985 928s 32v Auto
71k Miles
Black on Black
PPI revealed it has a slight leak in the PS resevoir and needs a front wheel bearing
It hasnt had the timing belt replaced yet
The outside condition is a 9/10
Inside condition is a 9/10
All electrical works
Original radio does not work (needs code)
Carfax check is clean
Tires all new
Service records going back to original owner
Last dealer service was at 45k miles
3 owners
Whats your guess on its worth?
If they are asking $10k is that too high?
If they are asking $5k is it a steal.
Old 11-23-2009, 06:40 PM
MPDano's Avatar
I dunno man, 9/10 is a very high standard there. Do you have pics of this car (in and out)? Auto or Manual? For what your describing, yup 5K would be a killer deal.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 11-23-2009, 06:47 PM
Petie3rd
Mrmerlin's Avatar
my 86.5 from another thread
http://forums.rennlist.com/rennforums/for-sale-ads-member-to-member-classifieds/534573-for-sale-nice-928s-1986-5-auto.html
And a list of work that I completed to give you an idea of what things will probably need to be addressed on your new purchase.
If you going to spend 10 K then you should buy mine.
If your going to spend 5K then you should buy mine, as you will spend over 5K doing all of the things i have done to my car, But good luck with your purchase
Old 11-23-2009, 07:10 PM
Petie3rd
Mrmerlin's Avatar
1986.5 928 S VIN WPOJBO928GS861833 Purch July 4 2009
Adjust sunroof, clean tracks, clean headliner, adjust liner
Replace hood shocks, remove rear shocks and lube balls.
Fix door panels and coverings, Remove aftermarket alarm, fit new washers to strengthen arm rests
Repair DS door lock and lube lock mechanicals, lube PS door mechanicals, repair both door arrestors
Aim headlights, adjust linkages, fit new E clip to motor arm, Polish headlight covers (overspray)
R n R rear hatch seal, clean and reseal, clean up headliner and refit rear visors
Fix RR tail light, resolder BCU, fix LR side marker bulb and connections
Replace windshield wipers, polish all glass
Replace the ABS relay and clean all wheel sensors, resolder anti skid computer.
Replace odometer gear and clean pod contacts, repair crack in pod, polish gauge glass.
Replace rear trans lines, and cover new with heat resistant line wrap, replace front clamps at cooler
Replace transmission filter/gasket and fluid, clean tank.
Check front and rear drive shaft clamps, (flex plate check) check crank endplay .006 in.
Replace PS reservoir and fluid line, add new fluid, replace in/out tie rods and new rack boots, no leaks.
Replace motor mounts with solids, clean all parts
Replace timing belt and add new bushings to the pivot arm, replace tensioner boot, fill with STP oil treatment. Inspect belt run, all the gears look good,
Replace: front main seal, water pump bolts, oil pump seals, clean all covers, tighten oil pan bolts.
R n R washer tank, and clean out, remove both metal collars, fix squirters.
Replace all fuel lines, inspect fuel system, replace engine oil 15W50 Valvoline and new filter
Fit hot post cover, clean contacts, heat shrink wires.
Flush out brake fluid and install ATE super Blue, clean out reservoir.
Fix front grill mounts, fix spoiler mountings, replace DS fog lamp bulb
Replace all 4 shocks install new Boge gas shocks, lube all adjustment collars.
Replace heater control valve and short hose, replace upper and lower radiator hoses.
Replace all 5 exhaust hangers and fit the stock rear muffler, replace header pipe hardware
Replace the sparkplugs WR7DC, replace cracked distributor cap, replace air filter, clean air pump filter,
Fix all engine vacuum leaks fit new 6 way vacuum T, Replace T fitting for breather
Repair glove box wires and fit new bulb, fix window switches, fix PS seat switch.
Check HVAC pods, and refit 2 in the center console, fix all console parts, and clean side covers.
Remove Charcoal canister, and refit correctly, replace Y fitting, clean out lines.
Scrub all 4 wheel wells and clean suspension parts, Clean all 4 ABS sensors at wheels, replace Emergency brake shoes, adjust E brake linkage.
Buff car and wax, polish X brace and radiator, scrub wheels, clean front fan and other parts, refill fan clutch with new silicone and polish pin. Lube all cable ends
Detail interior, fit new battery hold down, wash all interior glass, fix door speaker grills.
Remove rear Porsche letters, touchup chipped paint
Realign front fender and spoiler and nose section.
Charge AC system with Freon.
Alignment 4 wheel
Clean Idle stabilizer valve, repair loose vacuum hose connections
Remove the rear spoiler repair small rust spots on the hatch and spoiler connections, reseal screw holes.
Install new used ignition wire set.
Fix leaking AC clamp on low pressure line.
Replace the HVAC knobs.
Replace the fuel filter and the check valve.
Repair the Cruise control brain to full function.
And if you got this far you should have a nice running 928 that wont need to be on the jack stands waiting to get repaired
Old 11-23-2009, 07:14 PM
Thanks mrmerlin. I like black better.
Again my post is about my question and not your car.
So, does anybody know a source for values? NADA, KBB only go back so far.
Here are some pics of the car I am interested in.
Old 11-23-2009, 07:40 PM
Petie3rd
Mrmerlin's Avatar
Thats a good lookin car.
The door stickers are not my favorite but they do give a racy look.
I included the list of things i did to my car to give you a guide to the things that will need to be done to the one your considering.
If you use it you will have a better understanding of maintenance that will need to be performed.
You will absolutely want to replace the fuel lines and the trans cooler lines, as these are fire starters.
GLWP
Old 11-23-2009, 07:49 PM
SharkHead
JhwShark's Avatar
Sure is nice looking. Value is in the eye??
1985 928s 32v Auto 71k Miles last service at 45k (how long ago?)
I would be interested in what's under the covers?? Compression, fuel pressure, A/F.
Bad bearing on one side? check alignment and inspect that frame is true.
Needs to have a Waterpump and timing belt done, to be safe (interference engine).
How is the drive-train? Look at Trany oil for heating, Brakes...undercarriage, any crushed side-tubes?
Merlin, how did you fix the HVAC knobs?
Jon
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 11-23-2009, 08:04 PM
I already had a PPI done and only two things came up that was needed.
As I said, the car literally needs nothing. So much has been done I just dont want to list all the items like mrmerlin did.
What I a looking for is a website or something that says what the value of the car is. Is there anything that says the AVG RETAIL VALUE is $________________.
Old 11-23-2009, 08:18 PM
SharkHead
JhwShark's Avatar
No.
I would still do a WP and TB.
Old 11-23-2009, 09:25 PM
Network Native
Danglerb's Avatar
There is no fixed guide to the value of a 928, and this is double true for better than average cars. Better than average cars sell like fish, to the highest current bidder in the market for a better than average fish. I'm not saying this car is exceptional, but it seems like you believe it is perhaps just below exceptional, and if that is correct you should be more concerned about buying it before someone else does than whether it should be $8k or $12k.
Excellent car and great deal rarely combine. Who is going to keep a 928 in excellent condition and then sell it without some idea of its real value?
My PPI had a LOT more detail, compression across all the cylinders, two pages of check boxes and values. How experienced was the PPI mechanic with the 928?
Old 11-23-2009, 10:31 PM
928: Serial Enabler
Good points by Danglerb.
The sales prices are all across the spectrum.
85 / Early 86 32V Automatic is not the most widely coveted variety of the species.
You should budget $2000 for timing belt / WP and incidentals associated with that job. Bad wheel bearing can easily mean bad spindle on these cars, due to the design. If timing belt wasn't changed by 71,000 miles, then I'd scrutinize the rest of the maintenance as well.
Regarding where to look for valuation...Interestingly, its unlikely that anybody in the country watches 85 / 86 values more than the handful of guys you've already engaged here, on Renn and Reutter. Heck, Stan is a master restorer. Danglerb is using the premier 928 race and restore shop in the world to have his cars improved. No place better than here. I'd say on the surface you have it right with your first estimate. I'd lean low-side for several reasons. It would take detail, the story, the closeup photos, the PPI data to get a a better valuation. I'm dubious of car flippers and three of four low resolution glamour shots. Been there, done that. PPI must be done by a 928 specialist in my opinion. The dealerships haven't trained on 928s for over 15 years.
I've seen a 12K mile 85 auto change hands at around $13K in the last 6 months. It languished in the mid to high teens for a year.
I've also bought an 86 that's very nice with 71K from a retired guy for $2K, before the economy tanked, did the maintenance and tires and am still less than 5 for a car similar to the one you show. The point here is the owner may have very little in the car.
Valuing a Honda Accord or a Jeep Wrangler or a Burb, that's one thing. These are insanely complicated and seem particularly subject to being abused and then patch-detailed and flipped. Add the age to it and its clear that a deep dive needs to go on to value them.
84,85,86 928 cars
Old 11-23-2009, 11:42 PM
NO substitute
SharkTech's Avatar
Bra - fuggin - Vo...
Poetry, well said.
That closes this thread...
1979 928 5spd/LSD
CLEAN, Fast and Bad A$$
NEW INTERIOR
Old 11-24-2009, 06:18 AM
SharkHead
JhwShark's Avatar
Good confirming recommendations.
Try corelating the PPI you had done with this one: PPI
Maybe it will help you confirm the value of the PPI you had performed. Obviously, you need to understand how to...compare the two. But, anyone serious about owning and maintaining a SHARK can do this.
Jon
Old 11-24-2009, 07:44 AM
Dean_Fuller's Avatar
I would say a Timing belt job is a MUST as soon as the car is in your hands. Any pics of the engine compartment???
The seats are from a later S4 are they not? If all checks out well this car could very well be in the 10K range...but 3 pics all from the fount is not enough to make a REAL determination on value.
Old 11-25-2009, 03:16 PM
928 Newbie
dcrasta's Avatar
I make emotional decisions. Chances are you may not find another 86.5 in that condition. I would try to negotiate on price, but that seems like a fair deal to me if the PPI is good (try to get it for closer to 7k)...
Looks very nice form the 3 photo's you supplied.
Old 05-03-2010, 01:54 PM
Petie3rd
Mrmerlin's Avatar
so whats the verdict how much are they asking , how much do you want to spend? Is there a middle ground here for both seller and buyer??
Jon to fix the sliders you need to buy new slider knobs and be careful with the little curved metal sliding springs behind the panel.
Then the flex light cable plugs into the knob.
Note once the knobs are installed they are permanent if you remove them then you need new ones as the tabs will snap off if you try to remove them.
Note the HVAC head unit must be removed to replace these parts
Dcrasta the car in question is an 85, my car was an 86.5 and i was using it as a reference FYI
Old 05-03-2010, 02:38 PM
928: Serial Enabler
This thread is 5 months old. The OP is off posting about the 911 he's dabbling with. There is a high probability the car needed significant maintenance, despite the pretty paint and seemingly nice interior in the decidedly low res pictures. $3K-5K min parts only. At 70K+ miles, they all need mech. refresh. And dealer maint generally has been truncated. Needs timing belt? Then it needs it all.
Just like your's, dcrasta, and mine do, mechanical refresh needed. Though neither of our paint or interiors are as nice as this appears. PPI is worthless unless detailed by a 928'r.
I'd be a little lower (theoretically) at $5500: If no other damage revealed, cared for. I'd increase offer with step-ups for work proven complete on stan's list, but not very far. Excellent interior and body would mean a lot if confirmed, though. I get the emotion part, too, for a good, clean specimen. Agreed.
Am seeing an amazing number of cars surfacing lately.
84,85,86 928 cars
Old 05-03-2010, 04:56 PM
harborman's Avatar
Mrmerlin, I hope you are not selling your car after all you have done to it! You are the expert here!!! I thank you again for all your help!!! Many times over!!!!
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 05-03-2010, 06:26 PM
Petie3rd
Mrmerlin's Avatar
Well your welcome glad I could assist you.
For the car its been sold a few months ago,
a lucky local owner snapped it up.
That said it was a very nice car and with everything working as it should I will miss it ,
I had to sell it to pay off some debts
Old 05-03-2010, 06:39 PM
harborman's Avatar
Well, I hope you get another 928 some day. I have put about 2,500 miles on mine now and really enjoy driving it. It's taken some driving time away from my Harley but there were days here the weather was better driving the car.
1986 928S
32 valve engine
Old 05-04-2010, 08:27 AM
