-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Pulling engine, 1 question? (http://forums.pelicanparts.com/porsche-928-technical-forum/515602-pulling-engine-1-question.html)
Fredfox 12-09-2009 04:56 PM
Pulling engine out of my 86.5
Taking my time.
Why do they want you to remove the two transmission mount bolts at the rear of the car?
Am I looking at it wrong? Or is there a reason?
Mrmerlin 12-09-2009 05:35 PM
possibly to push the trans / front bell housing back a bit to aid in pulling the engine out /off of the motor mounts. Is this a 5 speed or an auto??
5sp needs the clutch pack removed first.
auto needs the flex plate disconnected, mark it to the flywheel
Arizona_928 12-09-2009 05:42 PM
makes sense. you need acouple inches, to clear the clutch ass. and to get the bell housing cleared.
Fredfox 12-10-2009 03:01 AM
Automatic transmission.
Barbapapa 12-10-2009 05:42 AM
Loosening those bolts will save the trans mounts from being contorted and allow the parts to move easier for alignment.
Fredfox 12-10-2009 11:16 AM
What about lifting eyes? There are none on the motor, are these just your normal homemade angle iron eyes?
Barbapapa 12-10-2009 01:59 PM
There's an eye at the right front and left rear of the engine. Are you sure they're not there?
Fredfox 12-13-2009 04:30 PM
Please, can someone tell me where the lifting eyes attach to the engine on an 85 - 86 928? I do not see any on mine and I am ready to extract. I do not want to get it too far off the Center of Gravity.
Picture would be nice.
MPDano 12-13-2009 05:06 PM
I can't answer for a 32V, but a 16V has two. One on each front and rear corner, can't remember exactly which corner. They are so off balance that even an engine tilt device wont get it even. I had to use a strap to the front pulley to balance the engine.
Mrmerlin 12-14-2009 10:45 AM
lifting hooks for the engine aare at the right front corner and the left rear corner.
I hope they are still attached
MPDano 12-14-2009 10:51 AM
Fred, if they are not there, just get a hold of 928 Intl and buy a couple of used ones (50% off) for a few more days.
Fredfox 12-14-2009 04:11 PM
Made my own, step 1 complete, now what???? Valves.
Found, cracked flex plate, bolts missing everywhere, lots of shabby work previously performed.
http://forums.pelicanparts.com/uploa...1260835901.jpg
Danglerb 12-14-2009 06:48 PM
Congrats on your outing. ;)
Mrmerlin 12-15-2009 06:47 AM
I would suggest that you tape a towel folded over to the top of each fender use blue tape this prevents most scratches from the work your doing the red cover will fit neatly along the front of the bumper cover to protect that as well
Danglerb 12-15-2009 11:51 AM
Roger from time to time does a deal on the real Colgan set, well worth the money.
XLR8928 12-15-2009 02:47 PM
God only knows what greasy wrench jockey was allowed to work on your beloved shark:(
morriss 12-15-2009 03:15 PM
Yikes! The engine was pulled with the radiator still mounted! I can't watch.
MPDano 12-15-2009 03:19 PM
Looks like the Condenser to me. Radiator would have Side Tanks.
Danglerb 12-15-2009 03:20 PM
Cracked flex plate, I wonder what iceberg that could be the tip of?
In the long run, I think its best to tear everything completely apart and put it back together renewing as needed.
Arizona_928 12-15-2009 04:26 PM
naa, I think that's the air condenser.
