Pulling engine, 1 question?
Pulling engine out of my 86.5
Taking my time. Why do they want you to remove the two transmission mount bolts at the rear of the car? Am I looking at it wrong? Or is there a reason? |
Petie3rd
possibly to push the trans / front bell housing back a bit to aid in pulling the engine out /off of the motor mounts. Is this a 5 speed or an auto??
5sp needs the clutch pack removed first. auto needs the flex plate disconnected, mark it to the flywheel
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
makes sense. you need acouple inches, to clear the clutch ass. and to get the bell housing cleared.
dolor et pavor Copyright |
Automatic transmission.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster. |
Loosening those bolts will save the trans mounts from being contorted and allow the parts to move easier for alignment.
Mike S. 79 928 Racer 427ci 32v 640WHP |
What about lifting eyes? There are none on the motor, are these just your normal homemade angle iron eyes?
There's an eye at the right front and left rear of the engine. Are you sure they're not there?
Please, can someone tell me where the lifting eyes attach to the engine on an 85 - 86 928? I do not see any on mine and I am ready to extract. I do not want to get it too far off the Center of Gravity.
Picture would be nice.
I can't answer for a 32V, but a 16V has two. One on each front and rear corner, can't remember exactly which corner. They are so off balance that even an engine tilt device wont get it even. I had to use a strap to the front pulley to balance the engine.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Petie3rd
lifting hooks for the engine aare at the right front corner and the left rear corner.
I hope they are still attached
Fred, if they are not there, just get a hold of 928 Intl and buy a couple of used ones (50% off) for a few more days.
Made my own, step 1 complete, now what???? Valves.
Found, cracked flex plate, bolts missing everywhere, lots of shabby work previously performed.
Network Native
Congrats on your outing.
Petie3rd
I would suggest that you tape a towel folded over to the top of each fender use blue tape this prevents most scratches from the work your doing the red cover will fit neatly along the front of the bumper cover to protect that as well
Network Native
Roger from time to time does a deal on the real Colgan set, well worth the money.
80 928
Yikes! The engine was pulled with the radiator still mounted! I can't watch.
1982 928 S Euro 5 speed |
Looks like the Condenser to me. Radiator would have Side Tanks.
Network Native
Cracked flex plate, I wonder what iceberg that could be the tip of?
In the long run, I think its best to tear everything completely apart and put it back together renewing as needed. |
naa, I think that's the air condenser.
