Griffinroydonal's Avatar
Auto transmission help
Hello, I am having a problem with my 87s4 Transmission slipping and wanted to know where to look to check fluid level. I was told my transmission was in the rear- I had that figured out MP-Dano. Thanks. I have not had any issues and was not familiar with the Auto transmission. Can anyone here be a little more helpful please ?
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 01-04-2010, 04:26 PM
MPDano's Avatar
dC AutomotiveOver 140,000 square feet of new and used Porsche parts
This is on a 78-82. Not sure on a later one.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-04-2010, 04:33 PM
MPDano's Avatar
87-91 shows a larger reservoir. It's there man. Guides don't lie. Around part #39
Old 01-04-2010, 04:36 PM
Recovering dismantler
neil30076's Avatar
Leo beat me to it - the last diagram shows the reservoir for the fluid - you need to either check out the owners manual, or the shop manual, for the correct procedure for topping off the level, do it wrong and you can cause major problems !
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 01-04-2010, 04:42 PM
Transmission help
pictures are just what I needed - Thank you very much !!
Old 01-04-2010, 05:15 PM
153bigblock's Avatar
Yes, Mercedes transmissions are sensitive to overfilling. Make sure your tranny is good and warm before you check it. Run the car for at least 20 minutes on the highway before you check level. Also, pm me your email address and I will send you a PDF of the Mercedes trans manual (722.xxx) and a diagnostic for identifying your issues.
Slipping or "flaring" can be as simple as a filter and fluid change, modulating pressure issues or the beginning of B2 band issues among other things.
Michael, So Cal
1985 Porsche 928, Black, 5 Speed
1985 Porsche 928, Weissgold Metallic, 5 Speed
1980 Porsche 928, Black on Black, 5 Speed
Old 01-04-2010, 08:29 PM
MPDano's Avatar
No Problemos. Also, make sure your car is at operating temp (warm). My OB (1981) reservoir has a notch on the metal bracket next to my reservoir which is where you want your fluid level to be. Not real sure where I read this but the level is checked with car at idle and on level ground. I know it's dangerous but this is how I check mine. I wish I knew where to reference this, but someone can chime in to make sure this part is correct.
Old 01-05-2010, 02:17 AM
928: Serial Enabler
Same way I check it, must be running. Can be done safer on 4 jackstands
To fill, I clamp a funnel to a 5/8 clear tube, zip tie to the fuel filler door
Snake other end behind the tire past the crossmember and to the filler hole.
Keep dirt out, might require some precleaning before opening the cap.
Filter change might also be a good idea.
What kind of slipping is it doing? Every shift, all the time, only in reverse, how?
84,85,86 928 cars
Old 01-05-2010, 10:06 PM
Transmission help
Car will pull off from a light with very little throttle and not slip. Hammer down on it and it slips in every gear. When you let off the gas the engine rpm drops and transmission catches up. Drive it easy and there is less slipping but if you push it there is a problem. This car had a New Porsche trans axle installed due to problems before I bought it. When more problems started the PO sold the car rather than fool with it. I am draining fluid and changing filter today to see what happens. I have been lurking post for a transmission for the last few months and will see what happens.
Old 01-06-2010, 05:16 AM
From the transmission manual:
TROUBLE SHOOTING
TRANSMISSION SLIPS IN ALL GEARS
Incorrect modulating pressure. Modulating pressure control
valve or pressure relief valve is dirty or sticking. Vacuum line to
transmission vacuum capsule clogged or leaking. Working pressure
control valve dirty or sticking. Low working pressure. Defective
primary pump.
Transmission Slips When Starting Off In 1st Or 2nd (Reverse
Is Okay)
Band B-2 shift valve sticking. Band B-2 piston worn or
damaged. Band B-2 adjusted incorrectly or worn or damaged. Adjust
brake band B-2 by installing a longer thrust pin (if necessary). If
transmission operates properly with selector lever in "2", but not in
"3" or "D" position, one-way clutch may be slipping.
Transmission Slips In 2nd Gear Or Shifts From 1st To 3rd Gear
Check control valve B-1 for ease of operation. Replace valve
body (if necessary). Remove and install brake band piston B-1, check
sealing ring and replace (if necessary). Replace brake band B-1 and
thrust body for B-1. Command valve binding.
Transmission Slips During 2-3 Upshift Or Slips Initially,
Then Grabs Hold
Check modulating pressure and adjust (if necessary). Check
for temperature throttle installation (if equipped). Valve body worn
or damaged. Replace valve body (if necessary). Replace inner plates of
clutch K-1 or recondition clutch (if necessary). Check front cover
Teflon ring.
Michael, So Cal
Old 01-06-2010, 08:16 AM
Network Native
Danglerb's Avatar
New as in the Porsche dealer had one sent in from Germany for $10k, or new as in rebuilt, or new as in new to this car fresh from the bone yard?
Sometimes the safest bet is to ignore anything the previous owner tells you and start fresh.
Old 01-06-2010, 08:46 AM
MPDano's Avatar
Originally Posted by Danglerb View Post
...or new as in new to this car fresh from the bone yard?
OMG, that's hilarious!
Or if you start from a wreck like I did, fresh fluid and filter made a huge difference. My only issue with mine now is the front seal has a small leak, which I need to drop the tranny for.
Old 01-06-2010, 09:02 AM
928: Serial Enabler
Not hard to drop them, considering all the other work you've done especially.
I just replaced a B2 piston with the upgraded version. That service can be done with the transmission in the car, BTW.
I'd drain the fluid from pan and torque convertor on this one. Refill carefully, get the fluid level above the lower mark when idling. (When you turn off, by the way, the reservoir fills completely up, so don't judge it unless idling)
You can check the vac by attaching a gauge back by the trans, starting car, reading gauge.
You can pull the cap on the modulator valve, flip out the key, and put a turn clockwise on it to increase pressure also. (I've read this is just a shot in the dark adjustment, Best to set-up via workshop manual with pressure gauges, watching responses while driving and shifting)
84,85,86 928 cars
Old 01-06-2010, 01:46 PM
help
The PO was anal about documentation on the Porsches he owned. I was supplied with a binder that contained documents and receipts for any and all service and repairs made to this car since it was purchased new. The reciepts are there for a new crated transmission from Porsche. There is also a signed letter from the service director of the Porsche dealership to Wolfgang Sander, District Service Manager for Porsche Cars of North America. The letter spells it all out so that rules out "Bone Yard" parts or rebuilt transmission. I believe all documentation to be true and correct with little or no reason to question what I was told by the PO.
There was a transmission swap made at the dealership after the new transmission was installed. At this point I have no idea what the hello will happen next. I have the filter kit as of today and will drain and fill asap. There is an auto transmission place near by that also builds transmissions for race cars and will take a look at. I would like to have a transmission that would put the power to the pavement as the car has been chipped, has headers , solid motor mounts , and a few other upgrades. I do thank you all for your time and attention with this post.
Old 01-06-2010, 03:52 PM
MPDano's Avatar
The front seal can be done on the car? Yes?
Old 01-06-2010, 04:52 PM
928: Serial Enabler
That's a Mr. Merlin question.
But I think you want to pull it out.
And that's really not hard. I was very aprehensive at first, but with a trans jack its doable.
84,85,86 928 cars
Old 01-06-2010, 05:38 PM
Network Native
Danglerb's Avatar
As I read the letter it says the previous owner found a core, a third party did the rebuild, and that was installed in the car and worked.
Pretty clearly the dealer was lost working on it, so back to step one, ignore what the PO says and start fresh.
How far are you from Steve Catteano?
Master Tech Transmission - The Premier Automotive Specialist of the Hudson Valley
Old 01-08-2010, 05:07 PM
neil30076's Avatar
and the shop was a ford lincoln mercury & hyundai - isuzu specialist - smart choice!
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 01-08-2010, 05:15 PM
Help
I am following your suggestion and going back to square one. I will wait a couple of days as it is 17 degrees here tonight and there is not enough heat in the shop
Old 01-08-2010, 11:17 PM
MPDano's Avatar
OMG! Neil is right. I just saw that on the Letterhead. Now you have no choice but to disregard that work. Square Uno my man.
Old 01-09-2010, 03:22 AM
