exciter wire terminal?
Okay, correct me if I'm wrong. Bolting the alternator up creates the ground; that leaves 2 wires hanging down, the fat hot wire, and the skinny exciter wire.
So, which terminal on the alternator does the skinny wire go to? #1 or #2?
1982 928 S Euro 5 speed
Old 01-22-2010, 05:09 PM
Forgot to number the terminals on the pic. #1 is on top, #2 on the bottom, of the lung-shaped disk on the left.
Old 01-22-2010, 05:12 PM
vdubr928's Avatar
Really hard to hurt anything hooked up wrong cause of the diodes but.
The blue wire looks like it feeds the coil. I would say that is the excitor post. Check with a Volt Meter but 1 and 2 may be the same.
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 01-22-2010, 09:45 PM
MPDano's Avatar
Weird how your car is just 1 year later than mine and it has a totally different Alternator. I also ended up bumping up my Alternator to a 120 Amp.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-23-2010, 05:17 AM
That is the one I have also, the big one.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster.
Old 01-23-2010, 06:01 AM
Dano- I have the Paris-Rhone and you have the Bosch. Could that be why they look different?
MPDano's Avatar
Yup, that be why. Pretty easy to figure out which wire goes where on my Alt. Not sure about Exiter Wire to 1 or 2 on yours, but I agree with Vdub as it looks like they are the same from your pic. Hopefully someone with a Paris Alt can chime in to make sure.
Old 01-23-2010, 06:19 AM
B+ is battery hookup-- 61 is exciter--D- is ground(but no wire) From your picture it looks like a D is stamped on the yellow wire side-a B on the blue wire side. Can't see the top. Look for a 61 stamp then you will be good to go. Hope this helps.
69 911 2.3Ez
85 928S
Old 01-23-2010, 07:01 AM
Woo-hoo, found the answer to my question. It is #1, the one at the top. It took some searching, but I came across this thread. This Sharkskin site is pretty awesome - tons of pics. And his car is an OB, so that helps a lot because a lot of the info I find when searching for answers are for later models.
SharkSkin - Shark Attack Round Twenty-One - Alternator
Old 01-23-2010, 07:16 AM
jstobo - thanks for the reply. I found the answer to my question, but I still looked for "61" just because. My alternator does not have a 61 anywhere, but no worries.
Now, on the sharskin site he says that the cooling shroud is pretty much a necessity to keep the diodes cool. I don't have one; could this be what caused my old alternator to fail (it only had 200 miles on it, maybe)? Or was it the fact that that my exciter wire circuitry was / is not working and I had to rev the engine up every time I drove it to get the alt. to self-excite?
Old 01-23-2010, 07:25 AM
