Recovering dismantler
neil30076's Avatar
Remote hatch release adjustment
My 84 refresh is coming along well. i'm getting down into the minor stuff now -
Like -
how do you adjust the remote rear hatch release mechanism - it cycles through one sequence fine when i pull the switch, but th d**n thing doesn't open.
TIA
neil
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 02-20-2010, 07:13 PM
Petie3rd
Mrmerlin's Avatar
try cutting a zip tie to the same width of the rear edge of the male portion of the latch , loosen the bolts and slide this along the rear edge and tighten the bolts also make sure the unlocktab in the receiver is moving inwards to the male part, the motor mount bolts can be moved a bit either way to add the distance inwards that the tab moves.
Do the rear zip tie thing first
Old 02-21-2010, 10:21 AM
neil30076's Avatar
Thanks Stan, working is interfering with my wrenching, i'll give that a try this upcoming weekend.
Neil
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 02-22-2010, 08:11 PM
