Uniroyal Timing belt
Well, I took the covers off the T-belt on my 1986, 928S with 38,000 original miles.
The old belt looks so new the manufactures Name and numbers are clear to read on the back side of the belt. It says, Uniroyal Power Grip HTD with the numbers DBP 1957922. Does anyone have any idea how old the belt is?? Is it possible the belt was replaced in 1992? I know the owner did not drive it much since then. I know time has lapsed, but the darn thing looks so good. I already bought a Gates belt and Laso pump. |
Is the 1986 an Interference Engine?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Then I wouldn't trust it then. If it was done in 1992, the the rubber is 18 years old. If that breaks, your engine is toast. Valves crashing on your pistons is not worth not knowing. Just replace it and document it, so you know when it has been done.
Network Native
Don't forget to take some pictures.
Yes, I am going to replace it. I was just wondering if that was the belt used at the factory. I worked a few hours on the car yesterday, taking my time, keeping things organized. Will put a few hours on it today. I am cleaning parts as I go, although they are pretty clean. I am putting parts on my work bench in order as removed. I can see with this car the thing to do is go slow, not force things. I noticed one bolt was missing on the right side cover in center. Will need to replace it. Rotors and caps look good, just a little cleaning maybe. Wires are stock and look fine. I know the plugs were replaced at 30K miles. I am putting PB Blaster on all bolts before I attempt to remove.
The center bolt on the drivers side cam cover is a special one, not your avearge bolt.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster. |
Petie3rd
Fred may be referring to the lower cover bolt as its a longer bolt IIRC its a 6 X 73 this goes into the timing belt cover then into one of the bolt holes for the water pump.
When you get the old pump off, go to ACE and get a new set of waterpump bolts and washers including the longer timing cover bolt. Use either antiseize or my favorite Loctite PTFE pipe sealant on the WP bolts this will keep any liquids from oozing into the bolt holes and corroding them. Replace the tensioner boot and block gasket, and use STP in a visene bottle to refill it from the hole closest to the passenger fender, do this with both bleeder nipples removed from the tensioner
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
I have one in my "garage" check it out. I did post about 3 but don't see them any more. I will put some others up. But my car is VERY CLEAN, VERY LOW MILES, ONE OWNER, NOT DRIVEN SINCE 1992. It is a gem!!!!
I had posted pictures showing the car and all manuals, cargo net, warrenty book, etc. Don't know why they removed them. I will take more. Don't care if you don't believe me, everyone here that has seen it in person knows!!!!!!!!!!!!!! Actually I posted some of the new radio I put in, did you not see those. I will take more pic's. |
I just checked my "garage" pic's they are still in there. Guess I need to take more. Anyway, I have a lot of "documentation" on the car, it's for real. Hard to believe I know! I now have two new front tires on it and the new JVC radio. Yep it's a real gem!
Network Native
Your car is indeed a rare gem, but not totally unusual as one or two if not more very low mile 928's show up every year, they are NOT however showroom or even safe to drive without many aged parts being replaced. Sitting without being driven has its own unique set of problems, that may show up right away or not until sometime later in the first few thousand miles of driving. Taking it slow is definitely the way to go.
It is a short stud in the block and a bolt with a threaded sleeve that screws on to it. As per the parts manual. I used a long piece of all thread 6X1.0 metric and put a nut on it and made a long bolt.
928: Serial Enabler
Not near as unusual as you think, but desireable.
These were 3rd and 4th cars for the affluent. Some had the **** beat out of them, others got tucked into the corner of the garage like an old baseball trophy. We saw an 83 and an 84 this year at Frenzy that had just been liberated with sub-40K. Then there are the Brunei cars. And Blue 82. That's a real story. 3500 miles, dentist owner gets mad at the dealer for attempting to rip him off, parks the thing in the back corner of his garage for 26, yes, 26 years.
84,85,86 928 cars Last edited by Landseer; 02-11-2010 at 10:40 AM.. |
