harborman's Avatar
Hatch Latch
My latch will not release using the motor. I am wondering if there is a broken part in the mechanism that the motor drives to release the latch. All I see in there is a small metal piece that moves up and down. Should this have a roller on it? Otherwise the latch works with the key. A minor issue, but it would be nice to get working. I tried looking at a parts brake down but did not see a more detailed drawing of this part.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 04-14-2010, 06:47 AM
SharkHead
JhwShark's Avatar
I'm not sure of the functionality of the mechanism. But what happens when you have an aide effect the switch, what does the mechanism do?
If no response at the latch, then try checking the voltage at the switch and at the control panel as well as the ground for the switch. You may be able to open the assembly and clean it. My rig has no switch and the latch does not seem to have a way to dis-assemble it. 928intl and probably Pelican sells the latch if it does not work.
Jon
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 04-14-2010, 09:00 AM
harborman's Avatar
Jon
The motor is working and moving the mechanism, but I think something is missing inside the thing, maybe a broken plastic part or something. I can't find a good parts brake down of that piece.
1986 928S
32 valve engine
Old 04-14-2010, 09:37 AM
SharkHead
JhwShark's Avatar
Well not sure where to go for a diagram but here is a page from 928intl with a couple of mechanisim pieces: pin & latch
928 International-LOCKS
Old 04-14-2010, 09:52 AM
These are a pain to get set. First try adjusting the mechanism. You can loosen the screws holding the motor mechanism and move the motor assembly so that you get more travel. If that doesn't work try shimming the part of the hatch lock that is on the hatch. Sometimes a shim on the edge moves it enough for the motor to release it. Finally you may have to replace the plastic lock catch in the hatch lock. They tend to wear and lose their sharp edge so the motor can't move it enough to release it. Not expensive around 10 bucks I think. You may have to do all of the above to get it to work. I spent the better part of an afternoon working on mine. The worst is when it works "some of the time". Good Luck.
69 911 2.3Ez
85 928S
Old 04-14-2010, 11:23 AM
harborman's Avatar
Upon further investigation, I noticed the top part was pretty far back. I took my allen's and went to loosen the two bottom bolts, but I found them to be lose already. I pushed the bottom part as far back as it would go towards the rear and now all seems to work just fine.
1986 928S
32 valve engine
Old 04-16-2010, 11:46 AM
