1982 928 us
what are the factory radio wire colors 82us
radio/cd unit .... all work but the power antenna doesnt go
what colors at the harness (console) are for radio ?
which is power
power antenna (would that just come up/down when power on off)
front left front right speakers -- rear left rear right speakers
what colors would go to what and if any im forgetting.
if antenna gets its signal at console? or ? thanks
Old 05-18-2010, 01:27 PM
MPDano's Avatar
I know on later radios (aftermarkets), there was a blue wire that powered the antenna. Have you tried to put direct power to your antenna? Disconnecting the stock power connector on the antenna first of course.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-18-2010, 01:37 PM
1982 928 us
the crimped is direct from end of antenna , the bundled red brown white (hatch motor?) and the blue black white seems to be useless wire from hatch to under seat dside. So where do the antenna (crimped) wires go.
Old 05-18-2010, 02:39 PM
MPDano's Avatar
You can get to your electric antenna by removing the rear wheel drivers side panel inside the wheel well (tub). Remove the screws that hold the panel on. It will be easier with the rim off too. This will give you full access to your antenna and the wires. You can then see the wire colors there. I am not at home so I can't tell you the wire colors, but i removed mine a long time ago. I put a Shark Fin on my roof for the AM/FM/Satellite antenna.
Old 05-18-2010, 03:21 PM
1982 928 us
yeah yours is cool i have the wheel/etc off the wires go through the grommet and in the pic there the ones with crimps on them white black brown?red? whatever color where to they go to get power for antenna a connector in trunk? or to the console? .......
Old 05-18-2010, 04:39 PM
1982 928 us
OK if i put power just to the antenna wires then which is pos / neg of the three?
I got a mast/cable for antenna unit, but to feed/install , the radio has to turn on power antenna motor up, then feed wire through antenna hole by turning the radio off.
I can fix antenna first off and have a working unit, then where/how? to take the 3 ant. wires and hook up.
theres a pioneer radio/cd player wired in there (like 1989 working junker)
yellow= +12v constant
red= 12v switch
black= ground
blue/white = remote on
speakers =
white/ wh-blk front left grey/ gry-blk front right
grn/ grn-blk rear left violet/ vio-blk rear right
ALL WORKING but no antenna, how do the cut wires get connection? HELP!!
Old 05-19-2010, 07:01 AM
1982 928 us
red wire off iginition for constant
blue off back of radio for switch power
pick up a ground wire SO FAR ???????????????????
that pic s***ks of course. lol
antenna wires brown/red
white blue?
black blue?
Old 05-19-2010, 07:16 AM
harborman's Avatar
white blue?
black blue?
On my 86 the White wire powered the antenna amplifier and triggered the power amp in the Pod next to passenger seat. I think Brown is ground. Always check with your meter before hooking up.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 05-19-2010, 07:34 AM
1982 928 us
I got , done!!! so glad i didnt have to resort to a pic of under console, you do know what i mean, though. BRUTAL.
back to welding my gas tank, Just Kidding!!!!
Old 05-19-2010, 09:05 AM
MPDano's Avatar
Excellent, now please post your fix, so others may learn off this.
Old 05-19-2010, 09:59 AM
1982 928 us
course everyones is different depending on what buying/wiring/modifying in
kidding right! basics is getting a ignition(red), constant (white), ground (black blue) Dont Quote Colors
manual for pioneer specific the model i have for colors which i did post and colors for porsche factory harness colors by manual specific to 82us. was first start
undoing wired in and hacked out wires from only knows who did what - added wires from a broken antenna/ for connector and to run wire front to back - tested for power turned radio on and antenna motor ran up. pulled broken one out paying attn to way teeth side feed through, directions on the mast/cable pkge, feed the new part/wire down into antenna . beautiful. button everything back up sweet!
*I think, which i dont have one of and spare didnt work that theres a relay so when car shuts off the antenna will go down automatically , mine doesnt have to shut radio off before shutting off car. Dont p-cars antennas go down auto?
My headlights stay up/not on too if i forget to shut them off before turning off car, correct?
nice to have radio for current events - wheather- some of those hilarous morning talk show peeps - other than that .... motor on.
Maybe reconnecting that rear wiper motor thats hacked too.
Old 05-19-2010, 11:01 AM
