1991 928 S4 GT
Porsche Crest 91 928 dash msg, "Differential control inop"
I hope someone may have seen this problem before.....
after starting my display shows "Differential Control off" and then Brake service required.
the dealer says both are fine and operational....
I have noticed that when I run the AC I get low voltage and I am wondering if this is result of low voltage to the control module.
I only have 23,000 miles and the car runs great otherwise.
Thanks for any help
Daryl
Old 06-29-2010, 07:48 AM
Petie3rd
Mrmerlin's Avatar
when was the last time you flushed out the PSD unit?? what is the charge rate at the hot post with the engine running?? use a volt meter to find out
Old 06-29-2010, 10:40 PM
