928: Serial Enabler
I drive an 84 Automatic daily with the system in the right of the picture.
Its very nice. I doubt it provides power increase. (Only juveniles want lots of noise and wheel chirp. My message to them is buy a mustang.) The 84 Automatic with standard timing is every bit as enjoyable as the 86 32V Automatic. The 86 is a little smoother, but both very powerful vehicles. Adjust timing and leave everything else alone. The only reason the 84 has this new system is that the old system was destroyed and I needed to replace everything. At that time, in early 2008, I had no network of folks to trade parts with. So I bought new and had it assembled. The system on the left belongs to a third 84 car and is shown for comparison.
84,85,86 928 cars Last edited by Landseer; 08-09-2010 at 01:20 PM.. |
Try driving a stick in Chicago traffic and see how sporty it i'd
928: Serial Enabler
There's something wrong with it. Another guy on rennlist is having that problem too and hasn't found his cause.
Check your manual again. You might have the pressure cable set so loosely that its upshifting very fast. The change occured in summer 87 according to the 1988 service information documents, so it was in full force for 1988. My 84 auto car has an 89 transmission transplanted in it. It starts in second unless given moderate throttle, then it starts in first or downshifts quickly to first. My 84 trans (when it was installed), 85 and 86 all start in first no matter what. Although, with a loose bowden cable, they rapidly upshifted and were sluggish. Other things can apparently cause this shift problem. Not sure what. Steve Cattaneo advised a guy recently that the B2 piston degradation might be the culprit. Not sure. I have changed one for other reasons, though, and its doable on jackstands.
84,85,86 928 cars Last edited by Landseer; 08-09-2010 at 04:46 PM.. |
That is the way mine works and from all the forums I have been at, these cars start off in second unless you put them in second and slow to a stop, or kick it down.. Some even start off in second even when manually pulled into 2 unless you pump the gas. there are lots of treads on this
Names Brad, Canada, Fort McMurray. Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476 |
928: Serial Enabler
Your car is different. Its an 89.
84,85,86 928 cars |
928: Serial Enabler
You are not the first to report the transmission behaving like this. People have been confused by the 2nd gear start and erroneously thought that the later-year change was the answer to the problem they were having with the earlier transmissions, 84,5,6 and some 87.
These three pages describe how the 4 speeds should work prior to the change in 88. ![]() ![]()
84,85,86 928 cars Last edited by Landseer; 08-09-2010 at 04:42 PM.. |
928: Serial Enabler
Here's the way later transmission shift, the reference being the porsche tech service information bulletin for the s4 cars which was phased in during the S4 production
84,85,86 928 cars |
80 928
Static setting would be around 8deg btdc. Sound more resonable? -Kerry
Thank you very much for that clerification Landseer. I stand corrected BTW awesome info
928: Serial Enabler
No problem, I'm sure the situation will be reversed many times.
I've had a little too much time on my hands this year and have been reading the CD set documents like a novel. |
928 Newbie
Dont mess with Landseer. He has been 'in this game' for a while.
Thanks for the 'chart' man that was pretty good info there. Looks like my car is working well, but not to derail this thread.. Is a symptom of 'hard' shifting a vacuum line leak? |
It can be.....I had the problem last week.....and it shifted very hard. Solved the vac leak and it shifts smoothly....in my case the hose had come completly off the line going to the TT and transmission....and I have not solved my starting in second problem.....
928 Newbie
Thanks. Figures I missed one . I did the vac lines last weekend. I have to get under the car again anyway. Wish I had a lift.
I found my coupling hose disconnected two weeks ago. Fixed it, put a fresh coupler at the tranny, fixed my hard shifting. Shifts very smoothly.
Don Mega
Could I replace Y-pipes and cat-back without doing the headers? A mechanic told me headers need adjusting repeatedly, so I wouldn't want to deal with that trouble. Does magnaflow make a y-pipe and cat-back for the 928S? Which brand is the best for the 84 928S?
Network Native
Nobody makes anything fun for the 928 that is Calif smog legal. The only options I know of that are legal, as in a muffler shop with a license will install it, are factory and the direct fit replacement in the Calif section of the magnaflow catalog.
My muffler shop made a Y pipe to match the US 85/86 manifolds, and combined that with a generic, but Ca legal at the time magnaflow cat, and made a cat back single chamber (loud) magnaflow muffler. Its really less of a technical question than what you can find a muffler shop willing to do, as they risk a very large fine for messing with smog stuff improperly. |
SharkHead
Jon
'79 928, 85k Opal Metallic '99 BMW 540i, 97k Titanium '72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga |
I use two gaskets to get a better squash. If you use a good quality header with a nice 1/4 or thicker flange then it is not so much a problem. this page says they have heavy flanges. Edelbrock.com - Exhaust - Headers - TES (Tubular Exhaust Systems)
