'79 928 Euro 5 Speed
Rupesy's Avatar
79 starter problem fixed
I've been having on and off problems with my starter.....been push starting quite a bit lately. I could hear the solenoid clicking. Sometimes if I clicked it 10-15 times it would crank over. Other times it would start the motor but not engage. I have a push button start and only use the key to put it in the on position. I decided to pull it last Sunday and check everything out. I took the solenoid off and noticed a lever it connects to. It is the lever that throws out the gear to catch the flywheel. It was really hard to push back and forth so I decided to go a little further. I pulled the motor apart and confirmed that the throw out mechanism was tight. I began to pull it apart (not knowing what to expect) and surprise....about ten little ball bearing came flying out! Luckily I was able to find them all. I noticed that the mechanism had grease or lube at one time and it was all dried out. I threw some bearing grease on it (not too much) and just enough to hold the bearings in place while I reassembled. Worked it over a little bit until it moved easily and then reassembled everything and it has been working perfectly ever since.
Old 10-27-2010, 08:44 PM
Petie3rd
Mrmerlin's Avatar
cool glad you got the starter figured out, Keep Em Flying!
Old 10-27-2010, 08:56 PM
Madman
wow, I had the exact problem to the letter (even the push button start). I bought a hi-torq starter. Mine is also a '79 HA. (auto)
-Anthony.
1979 Porsche 928 3sp auto, black (gone)
Yamaha FZ6R, Raven Black. (gone)
1997 VW Jetta GLX VR6 swap in. black (gone)
1988 Jeep Cherokee 4.0 lifted, mudders, roll cage, black (wife's)
Old 10-27-2010, 10:02 PM
Rupesy's Avatar
Where is your push button located??...mine is under the dash where the wiper delay is....PO drilled a hole and mounted it there. I'm not sure I like it there, but don't know where else to put it. I do like the push button start though...
Old 10-29-2010, 07:18 PM
