1982 928S
any one knows, if Dwain's tips on heater valve applies to 82 porsche 928 another word on older Porsche's. Ed.
http://www.dwaynesgarage.norcal928.org/ Last edited by georges 928S; 12-07-2010 at 03:19 PM.. |
Throw a link up
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
1982 928S
sorry MP its heater valve not regulator.
Yes, but I can't find this DIY your talking about. Put up a link.
1982 928S
Link posted in original post.
It says in the link (1987). That would be an S4
928: Serial Enabler
What is the question relative to your heater valve?
Yes, they all fail open, causing heat to not stop. Is that what you are asking?
84,85,86 928 cars |
1982 928S
mp, does any one have a link to show how to repair the heater valve on 82 model or equivlent. Ed.
928: Serial Enabler
Workshop manuals online should help you.
84,85,86 928 cars |
Theres a lot of pictures in his hvac diy. What specific piece are you talking about? Heater Valve is not a repair, it's a replace.
1982 928S
Hi Landseer, my quesion is ,to replace the heater valve are the instuction same as all models or its diffrent. another word is the heater valve behind the air cleaner on 82 models or is it diffrent. Ed.
It's behind/below your Air Cleaner. 2 Bolts under the Air Filter, then remove the long bolt goes thru the body of the Intake Spider. The Valve will stare you in the face.
Get to know your car and start pulling stuff like this off. You got a lot of maintenance in front of you.
928: Serial Enabler
its a good idea to change that short hose while you are back there.
84,85,86 928 cars |
