Need Help finding washer reservoir
I have a Right hand drive 1981 928S 4.7L and I am having difficulty finding the windshield washer reservoir. None of them are marked and do not want to be putting washer fluid in a place where it does not belong. If anyone could please help or possibly post a picture of where it is located that would be greatly appreciated. Thanks
Old 12-20-2010, 03:47 AM
harborman's Avatar
Well on my 86 USA it is located on the passenger side front fender behind the coolant fill. Near the firewall. Also a small one in front by radiator for special cleaner,
Old 12-20-2010, 04:49 AM
harborman's Avatar
Your coolant fill has a pressure cap on it, the washer bottle just has a plastic cap.
Old 12-20-2010, 04:54 AM
Petie3rd
Mrmerlin's Avatar
look through these links,
you may find an owners manual for the RHD and fluid locations.
Owner's Manual - Online - Rennlist Discussion Forums
European Shark
riber.bentsen's Avatar
Yep right here on page 65
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 12-20-2010, 05:15 AM
928: Serial Enabler
The washer fill pipe and the top of the tank that accepts fluid each have a carbon steel fitting as inserts.
This is a major design flaw with respect to the washer system.
Their remnants will probably need to be removed, tank cleaned and lines and sprayers backflushed, pump removed, disassembled and cleaned also.
(Unless this has already been repaired by somebody).
Out of 7 cars I've looked at, all 7 were affected, rust clogging everything, so you might have to do some work.
So, don't be disappointed if its not just "fill-and-go".
With some relatively minor work, the system can be restored!
84,85,86 928 cars
Old 12-20-2010, 05:41 AM
Brenton928S's Avatar
The washer resevoir is located behind the drivers side fender, to access it remove the splash guard to the rear of the rhs front tyre, pretty easy to access from there on in. Let me know how you go, i have to do some maintenance on mine eg, a good flush and clean the pump.
1982 928S M28.11 Auto
Old 12-20-2010, 08:22 PM
