1982 928S
Hi guys, need help again. 1. winding sound from rear when iam parked with engine running. 2. brand new brakes and rotors installed 1,000 miles ago and they are squeaking when coming to a stop. 3. electric cooling fan didn't kick on while getting close to red mark. thanks ED.
Recovering dismantler
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
1982 928S
3 problems
Thanks neil, so if i jump it and it runs, means temp sensor is bad, right. ED.
# 1 auto or manual #2 stock pad? try lubing contact points with a brake grease. #3 see Neils post. If the fan starts, change sensor. If not check fuse, there may be a relay too. then if there's power to the fan, the fans bad. I had something I unplugged wedge it's self in the fan an blew the fuse before.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
2) You need to bed those brakes pad in. Maybe a Google search or maybe here. 3) Disconnect the Electric fan at the Temp Switch at the lower front of Radiator, then jump the wires together. If the fan runs with the key on or car running, then it's the Temp Switch. Easy to do and I didn't even drain the Coolant. Just be ready to put the new one in as you remove the old. Keep the Cap on the Overflow as this will keep the Coolant from rushing out at full speed into your face ![]()
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
Not so fast, maybe your gauge on the panel is in-accurate - they tend to read wildly off - best way is to go get an IR thermometer at Harbor Freight, and check temps with that to be sure.
1982 928S
3 problems
Jumper the fuel pump relay, you'll instantly know if it's the fuel pump that's making the noise in question or not.
Raymond 1979 928 5 spd |
My fuel pump has been buzzing for years. Listen carefully when you turn the key to the run position. If your hear the noise before it starts and everything starts spinning, it's a good bet the thing your hearing is the pump.
