need shifter help .....
ok so I took my 82 928 to the shop to have the fluid changed and the shifter adjusted as it was poping outta 1st and not letting me have 5th after a week they are still having a issue with it .. if its on the lift everything works great but it will not do it on the ground ? ? please help as everything looks fine ..?? it is adjusted right
Justin Last edited by gibson36; 03-07-2011 at 11:42 AM.. |
Something got altered with either the front ball cup.....or .. the rear shift coupler. My vote goes to the rear shift coupler since it's much easier to see and get to on a lift.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
928: Serial Enabler
How long has it been doing this?
84,85,86 928 cars |
started after the master and clutch cylinders got replaced never been right after that .... I had 2 shops working on it to get the system bleed out done right and the car will shift fine 2-3-4-r just not in 1-5
European Shark
Are you sure they bled the clutch correctly. I just went through the procedure this sunday, and it's quite odd, and almost reversed thinking. Fluid goes in from the bottom, using the LF brake caliper bleed nipple to push the fluid in.
I had a trained and certified Porsche mechanic tell me the opposite, and of course it didn't work. So I went on here and found out how to do it, and now my clutch works better than ever. The fluid that came out of the clutch could easily be original, as it way totally ink-black.
1978 Porsche 928 Euro 5spd. Silver metallic/Black 1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed* Owning a 928 is risky business - but sometimes you just gotta say "what the fudge". |
If they put the wrong master cylinder on the car, it will not ever shift properly. There are two different length shafts for the master cylinder. You probably had the one with not enough throw installed. There are several threads on RL about this. There actually may be threads on this forum also.
The front ball cup could be a goner or the rear coupler may need to adjusted also.
928: Serial Enabler
That's right!!!
Rob Edwards posted a very clear picture the other day on rennlist of the cylinder and the modification needed, with measurements.
84,85,86 928 cars |
928: Serial Enabler
Here is the link. Rob's input is very nicely defined in the last couple posts. Same thing Stan has been saying here, too.
Clutch Master Is In. Why Is The Travel 3/4" Shorter Than The Old One? - Page 3 - Rennlist Discussion Forums Here's the money shot picture that this gentleman took, lifted from the post, in case you can't see the pictures on rennlist link. Note that the end has been grooved as it was before cutting (necessary). Seems, in summary, he removes 5mm from the small end of the piston and regrooves it. He did not shorten the spring.
84,85,86 928 cars |
