-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Its Back With Some Issues (http://forums.pelicanparts.com/porsche-928-technical-forum/601098-its-back-some-issues.html)
EIPtuningR32 04-04-2011 03:52 PM
Well, its back.... but its got some issues. The engine runs..........like poo. ill post videos of it running once i get them uploaded. it might be running rich, but i have no idea. anyone know whats up? it lopes like its got a mild cam in it.
EIPtuningR32 04-04-2011 05:31 PM
here is the videoPicture003.mp4 video by EIPtuningR32 - Photobucket
after i made the video i checked the timing (at idle) and the mark was paybe 1/4" - 1/3" to the right of the check hole in the cover.... i adjusted it and it is now running a little better, but still has some "rich" sounds to it. like the popping and stuff at idle as shown in the video. any ideas? how to i lean the fuel mixture? (i know, i feel as if some of my respect around this forum just disintegrated as i asked that)
ill link a better version of the video when vimeo is done with whatever it is doing.
Maleficio 04-04-2011 05:33 PM
I wonder if you have pressure issues stemming from defective fuel pressure regulators and dampeners?
When the vacuum diaphragm goes bad in these, fuel is allowed to be sucked into the intake along with the metered fuel/air thus causing all sorts of problems. Pull the vacuum tube from each and see if fuel spills out.
EIPtuningR32 04-04-2011 05:44 PM
where is it?
Maleficio 04-04-2011 07:25 PM
Originally Posted by EIPtuningR32 (Post 5943651)
where is it?
You've got three regulators, one of them is a dampener.
The dampener is right over the water bridge, front end of the engine. The other two are on the back side of the engine, left and right. You can see them because the fuel lines go through them.
EIPtuningR32 04-04-2011 07:52 PM
sweet. ill go check.
MPDano 04-04-2011 07:57 PM
82 Euro is L-Jet? Get some video of the engine. Your Volts look great.
EIPtuningR32 04-04-2011 08:40 PM
i think its k-jet.... no electric injectors..
MPDano 04-04-2011 08:53 PM
That's what I thought. Your CIS. You can adjust A/F with a long 3mm Allen Wrench.
I think I show the adjustment process in this video I made to show Mercedes Benz Injectors Installed.
<iframe title="YouTube video player" width="960" height="750" src="http://www.youtube.com/embed/rwOZdofaXsI?hd=1" frameborder="0" allowfullscreen></iframe>
Pete R 04-04-2011 10:22 PM
I have a warm start problem with my CIS. The accumulator doesn't hold pressure. It sounds a lot like that when I first start it...mine comes up to pressure and clears out however. It may be a pressure issue. I would put a gauge on it to rule that out immediately. The good thing is it's all mechanical, you don't have a bad "brain". I would start with the basics cap rotor plugs. probably could use a tune up by anyhow. Make sure every cylinder has good spark. In the process you can see if you have any lean or rich cylinders by what the plugs look like. After I knew it wasn't spark related I look into the fuel issue, if you found that the pressure was ok I'd look into clogged or dirty injectors. Did you say it's been sitting? If it has, is the gas fresh?
EIPtuningR32 04-05-2011 12:48 PM
are you referring to the fuel accumulator?
where can i get a euro S rotor?
are the caps the same for every model?
anybody recommend some wires? i ordered some kingsborne wires a while ago but they didnt fit and i shipped them back for a refund but never got the money back... $275 down the hole.... wont go with them ever again.
MPDano 04-05-2011 01:03 PM
928 intl can help you with good used parts and they also have a good economy plug wires for inexpensive. Also, your sponsor here (Pelican) have a good supply of new parts for our cars.
I actually use their Parts Diagrams for part numbers.
Pelican Parts Porsche Parts Diagrams and Locator
rhjames 04-06-2011 10:31 AM
I'm not there, so you take this for what it's worth---
if your K-Jet is suffering with what sounds like cam lope, I'd start with vacuum leaks.
many years ago, in a galaxy far, far away.....when I first bought my Euro it had the same issue.
cause: intake manifold boots had huge holes in them and were swelled out like pumpkins.
cure: replaced the boots and all was well (except for the 7 busted pistons that came along later)
you can adjust the flapper (causes it to go lean or rich) in your K-Jet by turning the allen screw just in front of the fuel distributor, but that's probably not your problem.
you could also get a CIS gauge kit to check fuel line pressures and such. Warm up regulator is another issue for CIS.
EIPtuningR32 04-06-2011 05:02 PM
okay, so i changed the spark plugs today and here is what i found:
http://i573.photobucket.com/albums/s...rkPlugs005.jpg
http://i573.photobucket.com/albums/s...rkPlugs004.jpg
http://i573.photobucket.com/albums/s...rkPlugs003.jpg
http://i573.photobucket.com/albums/s...rkPlugs002.jpg
http://i573.photobucket.com/albums/s...rkPlugs001.jpg
do those white looking ones mean iam running lean?
MPDano 04-06-2011 05:08 PM
They look good to me except #1 & 3. Maybe a leaking Injector causing a rich condition. Doesn't look like oil so seals and rings would be fine.
You can replace those 2 injectors and just do all with the Mercedes ones and be done.
EIPtuningR32 04-06-2011 05:36 PM
any idea why the engine wont rev past 4K? it starts sputtering
Pete R 04-06-2011 05:46 PM
CIS injectors spray all the time like a garden hose...so they are always really leaky ;) They could be dirty however resulting in a bad spray pattern an not allowing complete combustion.
How old is the gas?
Is the plate that controls the injector flow operating though it's entire range?
You may also have a bad coil that breaks down at higher rpm's too. (do you know anyone local you could do a quick swap with to test?)
just throwin out idea's here, a condition like that can be almost anything
EIPtuningR32 04-06-2011 06:35 PM
How old is the gas?
the injectors do need attention, i plan on getting the mercedes ones, but Summit is out right now, so i am going to wait until they get their restocking shipment in.
the gas is two days old. In two days, i have gone through half a tank, is this normal? I have driven maybe 60 miles tops....
i have no idea what you are talking about when you refer to the plate that controls the injector flow... are you referring to the fuel distributor?
I know of no one local that owns a 928, much less one that would lend me a coil pack.
gbgastowers 04-06-2011 07:47 PM
I have basically the same car and problem as you. Mine is running like poo also. No power under load but when it gets going I can rev it way up(tach not working) as long as I'm not going up a hill. I am getting no alternator power even though I have a new alternator and battery. I have been through the whole pod and gauges(checked bulb at voltage gauge) and the issue still persists so now I think I'll go after the" bad blue wire from alt to 14 pin" theory. I see that yours is charging good. When mine gets the revs up it makes a rapid staccato popping from the exhaust and kicks in like a turbo. I think this shows me how it's supposed to run when all is well. Mine also drinks the gas like a tank. 10MPG but I think it will get better when I get it running right. Gunarhttp://forums.pelicanparts.com/uploa...1302144261.jpg
http://forums.pelicanparts.com/uploa...1302144433.jpg
EIPtuningR32 04-06-2011 08:17 PM
haha, i wouldn't use mine as a benchmark. its a heap of junk. the only reason why i am not selling it and buying a good one is because i am a hard headed fool who wants to set things right on my own. the interior is HORRID. Nothing, and i mean nothing, electrical works on the car, except the brake lights and turn signals. anyone know of someone that can COMPLETELY rewire a 928 or has in the past that could lend me a hand?
anyways. i have those same wheels... whats the story behind these things? how much are they worth?
http://i573.photobucket.com/albums/s...SWheels003.jpghttp://i573.photobucket.com/albums/s...SWheels002.jpg
gbgastowers 04-07-2011 03:41 AM
I think they were a dealer installed option. They are a very well made, light, expensive wheel by a German company known for race wheels. No one likes the dated style of them anymore so they would be hard to sell. I like mine mostly because the offsets are perfect and gives my car a desired stance.
MPDano 04-07-2011 07:09 AM
I guess what I am trying to say is that his Spark Plugs are not a consistent color. It looks like we have a Normal Color and a Couple Rich Colors. To me looks like Fuel issues. Since his Injectors are probably the original 30 year old ones, why not replace all of them with some brand new Inexpensive ones then move up the path. Could be his Fuel Distributor and/or little filters in the FD.
Yup, understand the CIS (Continuous) part and I am thinking even thought they are continuous, they still need pressure to push fuel through them. Take an old CIS Injector and try to blow through it. No go. Put a little Car Cleaner in it and put an Air Compressor behind it and walla, Carb Cleaner and you can see your Spray Pattern.
I was also running terrible with my Old Injectors and by pulling the plugs I noticed one was very clean. Turns out, the Injector was faulty and blocked. Hence why I was running on only 7 Cylinders.
Replace the 30 year Injectors/Seals and move up the Stream if it doesn't completely resolve the issue. FYI, go to A U T O H A U S A Z .com for those injectors. Cheapest place around and great service.
rhjames 04-07-2011 08:36 AM
if you have spark leakage--you can try looking at the engine at night when it's running (sitting still of course).
if you have spark plug cables leaking, you'll see it.
also check the inside of your distributor cap--dirty cap = bad ignition. same goes for the rotor.....
still think you need to verify no vacuum leaks.
gbgastowers 04-07-2011 11:29 AM
Can you list the common areas where vacuum leaks occur. I know the hose coming out of the brake booster is one.
EIPtuningR32 04-07-2011 06:59 PM
i found them on summitracing.com for $5 cheaper than that place..... $22 per injector.
EIPtuningR32 04-07-2011 07:00 PM
sweeeet. iam going to go look for a light show. SmileWavy
MPDano 04-07-2011 07:00 PM
Wow, I am surprised. Good find! Although not in stock, but if you waited this long ;)
EIPtuningR32 04-07-2011 07:17 PM
took the words right out of my brain. :eek:
EIPtuningR32 04-07-2011 08:27 PM
Frog007.mp4 video by EIPtuningR32 - Photobucket
so, this is what its like on start up some times... any ideas whats up with this?
sorry about the video, i shot it tonight.
MPDano 04-08-2011 05:21 AM
Besides the Injectors, look at your Fuel Accumulator (known for hot start problems) for leaking. Do the Tune Up stuff (Plug, Wires, Cap and Rotor). Clean out all the small filters in the WUR and Fuel Distributor, then run the sheeit out of it.
EIPtuningR32 04-08-2011 12:40 PM
do i disassemble the fuel accumulator? if so, where do i look and for what?
MPDano 04-08-2011 12:46 PM
I never had to service mine but I think it's in the right rear wheel well in front of the tire. Behind the Panel. Check for leaks. There is no disassembly, if it's bad, it's replace time.
Pete R 04-08-2011 12:47 PM
I would do tha accumalor last. I doubt this is your main problem. A bad accumalor like Dano says creates a "hot" start problem. once it starts it will build pressure and run normal. You have something else going on.
EIPtuningR32 04-08-2011 01:03 PM
any ideas what this something else is? i know i have blow-by... oil comes out of the oil fill thing when i rev up the car in a spirited drive.
rhjames 04-08-2011 01:08 PM
this is typical for a 16V engine.....there is no blocking plate under the oil fill canister, so the oil that slings off the crank goes right up to your oil fill canister and then gets sucked into the intake manifold.
it's really bad when you have broken rings or pistons---ask me how I know.....
MPDano 04-08-2011 01:19 PM
Yup, when I had the whole top end off my Euro Engine, I bought one of those vented cover thingy boppers from 928 Motorsports. Problem solved.
928 Motorsports - Porsche® Performance Parts - Oil Control Baffle For The Porsche® 928
http://www.928motorsports.com/parts/...%20(Small).JPG
EIPtuningR32 04-08-2011 05:08 PM
how hard is that to install?
MPDano 04-08-2011 05:52 PM
It's very easy to install, but I really don't remember if something else needed to come off first. Remember, I did this with my whole Intake was off. Someone can chime in on this one.
EIPtuningR32 04-08-2011 06:42 PM
yes please, if someone knows it would greatly be appreciated. this may stop oil from spraying out of the oil fill all over the engine!
sonett3 04-08-2011 07:05 PM
Does not work very well .... Get a scrubber for it .
