turn signals???
1980 928, all turns signals are inop. Emerg flashers are also inop.. This car has very little if any corrosion. 56,000 miles.. Point me in the correct direction....
Thanks Phil |
80 Fuse/Relay Chart
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
inop turns
Fuses are all good. opened up the relay, all looks new..
When I had my flasher button out of the pod the turn signals would not work. When I reconnected the flasher button everything worked so you may have a bad flasher button,flasher relay or bad connection to the button. It completes the circuit I am guessing. Gunar
82 928 Euro S 5 speed, sport seats,Moss Green/Champagne 04 996 C4S conv tip Polar Silver/Metropol blue |
A relay can "look good", but be bad. You've got to read it out with a meter with 12 volts applied to throw the internal switch to verify.
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
When you say "inoperable" do you mean they don't blink or don't light up at all?
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's) 1989 Auto Slate Grey Metallic / Cashmere & Black (mine) 1982 5-speed White / Black sport seats ( brothers ) |
Petie3rd
warning dont let the pod switches lay in the holes unless they are seated or pulled completely free of the pod to do risks a short as the switches can easily ground to the pod since its aluminum and short the wire back to the CE panel.
Since your having issues with the flasher and TS I would disconnect the battery then pull the switches out and verify that the correct wires are going to the correct switch some of the wires/ plugs will fit other switches, once this is done then remove the lower steering column cover and inspect the rear of the TS switch see if possibly it has been mis installed and the connectors are not on the pins
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
got it fixed
I did a by pass with the relay, flasher workes. Replaced the relay, system checks ok.
Ah, so you put the old one back in after doing a bypass, then sounds like your contacts were just dirty. Time to dig into your CE Panel with a small wire brush.
