1979 euro
jonb928's Avatar
1979 euro flooding
I have had some trouble after the car gets warmed up with it acting flooded if the car sets for 30 or so minutes. It starts good cold and if you start it shortly after shutting it off, otherwise you have to give it gas and clean it out after starting. I also notice a little miss at an idle. Just wanted to know if anyone has a idea of what could be the problem. I was thinking the injectors may need cleaned. Any Ideas would be greatly appreciated. Thanks
Old 05-09-2011, 03:50 PM
MPDano's Avatar
Check if you have a leaking Accumulator. This is know on CIS cars and to cause hard hot starts.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-09-2011, 04:17 PM
Maleficio's Avatar
Does this car have a cold start valve? If so, could it be operating when it shouldn't?
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-09-2011, 04:24 PM
'79 928 Euro 5 Speed
Rupesy's Avatar
Try disconnecting your cold start injector or thermotime switch once the car is warm. If it eliminates the problem, then your thermotime switch in the cold start circuit could be bad causing the cold start injector to fire whenever the starter is engaged (cold or warm). It could explain why it starts good cold and floods when warm. It something you can try quickly and if it does not solve the problem you can move on to more complex stuff.
'79 Porsche 928, '00 Porsche Boxster,
'86 Porsche 944, '04 BMW Z4
'77 Fiat Spider 124,'07 Chevy Suburban LTZ
'83 Jeep CJ7, '06 Harley Sportster
Old 05-09-2011, 05:26 PM
1979 euro
jonb928's Avatar
I will check out the cold start valve. Thanks
Old 05-09-2011, 05:33 PM
1979 euro
jonb928's Avatar
cold start valve unplugged
I unplugged the cold start valve and tried starting hot. I still acted like there was a couple of cylinders were fouled or not getting gas. If I rev the engine a couple of times it comes out of it. It does have a slight miss when running at an Idle. Any other idea's, maybe dirty injectors??
Old 05-25-2011, 09:49 PM
MPDano's Avatar
Pull plugs and compare. This will give you an indication of a working CIS Injector
Old 05-26-2011, 04:19 AM
All your symptoms appear to indicate leaking and or clogged injectors. Try a couple treatments with Techron or Gumout cleaner to see it to clear up the flooding/missing. The hot start problem may be the leaking injectors or some other problem. The following link provided a good starting point for diagnosing the hot start problem.
924Board.org :: View topic - Regimen for correctly diagnosing Hot Start Problem
Dennis
Dennis
Old 05-26-2011, 06:12 AM
MPDano's Avatar
Yeah, and especially on a 79. Those are 30+ Year Old Injectors. Replace them with some Mercedes ones and be done with it.
Old 05-26-2011, 06:17 AM
Pete R's Avatar
I would bet it's the accumalator. I have the same issue (with new injectors). I was told that when the accumulator doesn't hold pressure the heat from the motor causes air bubbles in the fuel. When you start it, it stumbles and runs funny until the air is purged... at least that's my issue.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 05-26-2011, 06:43 AM
MPDano's Avatar
Yeah, that was my first suggestion on Post #2, but it seems as if he moved on. Doesn't hurt to put new Injectors on a 30+ Year Old car, but yes check your Accumulator as recommended.
Old 05-26-2011, 07:25 AM
Pete R's Avatar
I was trying to lead him back to your point. I agree it can't hurt to change 30 year old injectors either but in the end I don't think it's the root of his problem since it runs fine cold and hot and is just a start up issue.
Neon SRT4 track car
Old 05-26-2011, 05:34 PM
