Rear diff fluid change 928s auto
How does one change the fluid in the rear diff on a 928s us auto?
Has anyone tried the synthetic fluids like Amsoil? |
928: Serial Enabler
This part is easy.
Conventional (tapered) plugs to remove, 17mm hex. Use a pump or run about a 1/2 inch hose from the fill hole, through the right rear fender well, and zip tie it to the fuel fill door. Fill. Am using Mobil 1 LS synthetic, on some, Valvoline inexpensive stuff on others. I think it calls for 75W85 or 75W90. At least 2 qts / check book. Don't overtighten plugs on reassembly.
84,85,86 928 cars |
Make sure you remove the fill plug first. I read this one is sometimes difficult to open, before you drain the case.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Synthetic from conventional switch on this no problem?
+1000 I almost totally screwed myself with my wife's CRV by removing the drain plug first. There were several tense moments of sweat and nausea.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
928: Serial Enabler
No, it hasn't been for me on engine, trans or diffy, regardless of mileage, 10 different Porsche cars, from a leak perspective. Am using new pan gaskets in engine and transmission on most of the cars. The ones with cork gaskets (944) weren't leaking, so its fine. If your gaskets are already leaking, some say that the synthetic might accentuate it. Don't know.
On the automatic transmissions, though, am now using Valvoline High Mileage ( red container ) these days because the Mobile 1 trans fluid doesn't shift as firmly on a couple of my cars as the Valvoline. The Valvoline might not be synthetic. I think the issue is the friction modifier package as opposed to the origination of the oil portion.
84,85,86 928 cars Last edited by Landseer; 07-22-2011 at 05:13 AM.. |
I'm running Amsoil in mine, plus a dose of Tufoil. Works great.
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
I do remember Mrmerlin saying to open that fill plug on differential first before draining as some were hard to get off. I might tackle that job as well.
928: Serial Enabler
Yes, you are right, I got that totally sideways!
But he and I were corresponding separately a few days ago on the trans fluid, so it must have gotten tangled up in my mind. Good call, bad communication on my part. The 5 speed has the diffy open to the trans, so they fill as-one with gear oil. The auto uses gear oil in the back, and trans fluid in front. Valvoline and Mobil 1 are brands of both gear and trans fluid --- am using all permutations right now, gets confusing sorry.
84,85,86 928 cars |
I am going to try amsoil trans fluid and amsoil gear box fluid just waiting for new trans filter
Are you also going to drain the torc converter?? Otherwise you leave a lot of old fluid in the trans. There is a drain plug on the converter but you need to position the plug by rotating the crank by hand. They also suggest getting new plug seal washers. I just did this job a few months ago.
yes will drain convertor as well
You will feel the difference immediately.
I just did my Differential fluid change today. Got a 17MM hex allen 1/2 drive socket at Autozone for $11, actually a 3 pack. The plugs came out easy on mine. I put some anti-seize on them before reinstalling them. My old fluid was actually not too bad looking but this car was well kept! As was the trans fluid when I did that. The pan was clean. Anyway, now I know it's all new.
928: Serial Enabler
Changing all the fluids, at least once at beginning of ownership, seems like a very positive thing to do.
We've begun disecting filters for clues to condition. Messy but revealing.
84,85,86 928 cars |
