coolant temp sensor
I think I have a faulty coolant temp sensor
Is this the sensor that is located at the top of the water pump
There are other sensors on the engine and want to make sure I get the coorect part
Thanks for your help
Regards
provenceman
Provenceman
1987 s4 Diamond Blue
Auto Trans
Old 09-04-2011, 08:51 PM
mproseusa's Avatar
I believe you are talking about the Temperature Sensor II. It is located on the Water Bridge just above the thermostat.
There are some testing parameters included above. Test to be sure the sensor is bad before replacing.
Mike
1982 Porsche 928 Auto Black on Black - Competition Package
Old 09-05-2011, 09:47 AM
mproseusa's Avatar
EDIT - Sorry, I didn't check the MY - The info above is for the early 16valve engine. I don't have the WSM for the 32 Valve models.
Mike
Old 09-05-2011, 09:52 AM
coolant temp sensor
No problem
Thanks for responding
provenceman
Provenceman
Auto Trans
Old 09-05-2011, 11:12 AM
