European Shark
riber.bentsen's Avatar
Massive engine coolant leak!
I just parked my car a few minutes ago, and noticed some steam at the very front of the car coming from the grill. I didn't take notice at first because we had a light sprinkle of rain but the steam kept appearing and caught my attention.
Opened up the bonnet and it smelled sweet-ish, ran my fingers across the bay (it is dark outside) and picked up some greasy liquid. Fetched my emergency torch from the glove compartment and started searching for leaks but couldn't find any? The radiator is wet down the left hand side, and i poured about an ounce of water out of the air intake pipe. Toothbelt is dry.
WTF has happened? It was running great, and no warnings on the dash. I'll take some pics tomorrow too dark now. Oh, and the coolant reservoir was bone dry, but engine wasn't overheating..
What is the most probable source of the leak?
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 09-04-2011, 11:49 AM
Maleficio's Avatar
Split hose?
There is a small hose that runs along the top of the radiator that runs to the reservoir. Mine busted open at the t-fitting under the fender sill on the passenger side.
That would explain the dry tank.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 09-04-2011, 12:12 PM
European Shark
This is drivers side, and the tiny hose on top was my first guess too - totally fine
Old 09-04-2011, 12:19 PM
MPDano's Avatar
You should post pics of the wet area, then the whole engine area. Just to give us an idea of where to suggest.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-04-2011, 12:31 PM
Petie3rd
Mrmerlin's Avatar
your left or right will mean more when you can define what it is ,
try while sitting in the car the ???? side of the radiator is wet ,
My guess is the inlet to the radiator or top hose side end tank has split at the seam where its crimped to the core.
Roger sells new tanks and O ring seals you replace both the tank and the seal and usually the inlet side of the radiator is the one that gets swapped out the outlet side doesnt usually cause issues
Old 09-04-2011, 12:36 PM
European Shark
Left is of course drivers side, as always when pointing out something on a car...
And MP, read the post it's too dark for pics
Old 09-04-2011, 01:51 PM
Maleficio's Avatar
I figured you were describing your engine as you were seeing it as if working on it.
I try to describe engine bay locations with "passenger or driver side".
Hope you can fix it cheaply.
Old 09-04-2011, 01:56 PM
MPDano's Avatar
Riber, invention called Flash.
Old 09-04-2011, 02:53 PM
MPDano's Avatar
Exactly how I thought it was. Most of us describe as if we are working on the vehicle from the Front facing engine. Like Maleficio says, unless you specify pass/driver side. The confusing part though is that there is such a thing as a RHD (Right Hand Drive).
Hence, why I asked for pics.
Old 09-04-2011, 02:56 PM
Maleficio's Avatar
Maybe it would be better to say "port or starboard"? No confusion there regardless of driver configuration.
Old 09-04-2011, 02:58 PM
Pete R's Avatar
A hose is the most probable. As soon as it's light it should be pretty self explanatory. If it's dried up fill it up with water and start the car (don't overheat it). It sounds like it will show up pretty quick. Unless one of us stands next to the car we are all just going guess and name every possible hose, seal and random source we can think of
btw you didn't get a low coolant light with an empty reservoir? somethings not working right there
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 09-04-2011, 07:12 PM
Maleficio's Avatar
Good points, Pete.
Old 09-04-2011, 07:47 PM
European Shark
Problem solved!
It was just a pin-point leak in the main return hose that would only show when the system was under pressure. Quite clear in daylight, frustrating late in the evening..
The reason I flipped is because my girlfriend and I have just done a 3000 mile roundtrip of Europe without any hint of trouble from the car, cruising at 100 mph on the autobahn all day with occasional bursts to 140 to show the odd Merc or Bimmer driver who's boss
We come home to good ol' Denmark and first the car refuses to start for two days (faulty relay), and now this? Just glad it didn't happen somewhere in Italy.
Thanks for your time and help as usual.
Old 09-06-2011, 02:15 AM
Petie3rd
Mrmerlin's Avatar
THIS Thread.........
Old 09-06-2011, 04:21 PM
Porsche newbie
Niles's Avatar
...is worthless...
87 928 S4 Exported for Japan
Old 09-07-2011, 04:27 AM
MPDano's Avatar
...without following the the advice on Post #4
Old 09-07-2011, 05:30 AM
