Widow Switch Replacement
I just replaced the second switch. Window would go up but not down.
Simple job, remove side panel and unplug switch connector (disconnect battery first). I then clipped the 4 wires near the connector. With a small flat blade screw driver, gently pry up on the back of the switch and lift up. Now you can pull the old switch and wires out. Now feed through the new switch and wires. Take the old connector and label it with magic marker, the colors on the side of the connector. Now with a small nail you can push in on the old contacts to push back the tab that locks them in and slide the contacts out. (Look at the new contacts to see what I mean). Now you simply insert the new wires & contacts. They will "click" once in place and lock in. Plug connector back in and you are all set. No splicing or soldering needed.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Petie3rd
pictures please
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Or you could buy a new switch off eBay for cheap, and not have to do anything except remove and replace.
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
I bought the entire switch and cable attached for reasonable price, all new! from Roger. No big deal! I was just trying to point out how to do the replacement without soldering or splicing the new cable. You still have to feed the wires through the switch plate on console , right???
Oh, I thought you were saying how to replace the internal switchery and wiring so you could re-use the original assembly.
No, I guess you could just unsolder the old switch, if you have enough cable to work with, then take a new switch and solder all the wires on, if you are good at soldering and get everything right. Might take you a bit longer for sure. Not worth the time or energy in my opinion.
I just did this in job last week. I replaced the sunroof switch and PS and DS window switches. The PS window switch connector is far back in the dash, but still totally accessible. Snipped a few zip ties, unplugged, replugged new ones and zip tied them back the way they were. I am not sure why anyone would want to solder new switches on. The hardest part is being careful to remove the PS carpet panel on the side of the console as there is a metal tab that goes through the carpet piece instead of sliding on like the DS carpet panel. I would rate this job a 2 out of 10 on my difficulty scale. Chances are your center console rear tabs are broken, and you will need some big ass washers to hold them down or order replacement tabs from Hookedoncars.com
Michael, So Cal 1985 Porsche 928, Black, 5 Speed 1985 Porsche 928, Weissgold Metallic, 5 Speed 1980 Porsche 928, Black on Black, 5 Speed |
