Power Steering Fluid
OK, so I'm looking under the hood for something to mess with and noticed the power steering fluid level down a bit. Pulled some power steering fluid out of the cabinet and topped it off. Then not two days later, read that 928's don't use regular power steering fluid, but AT fluid. How messed up am I....do I need to drain it all and replace with ATF, or just ignore things and see what happens?
1982 928 us
drwdds post up ur yr/ model/ man,auto too.
1982 Porsche 928 us |
Sorry....forgot the drill....been a while since I've posted. 1981 Euro automatic.
I got the same year. Either way, I also put Power Steering Fluid in mine. No issues last 2 years. They are both hydraulic fluids, not really sure what the diff is, besides the color. I'm sure someone here knows though.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
1982 928 us
what did you use like prestone? p s fluid. does back of bottle say its dextron atf compatible.
with mpdano its hydraulic fluid. it would be then lubrication factor
When in doubt, read the directions. The owners manual states that the power steering unit uses any Dexron-D type of ATF. The back of the Prestone power steering fluid bottle doesn't say anything about compatibility with ATF. Since both products are basically hydraulic fluids, the advantage of ATF is it's lubrication properties. Think I'll just leave it alone and see if there is any adverse effects of mixing the two together.....a cautionary tale for everyone else!
928 Newbie
Use what the transmission takes .>Less stuff to have in the garage .
FWIW I use ATF in the Powersteering so Its easier to spot leaks. |
I would be inclined to dump it and fill it with the right stuff. The ps fluid may have different seal conditioners in it, it may make them swell or harden. It would be a slow process and not noticeable until it leaks. The fluids may also react together causing foaming or other issues. then agian.. it may be not problem at all, it's just hard to say, but how much is a couple quarts of the right stuff really? Brake fluid is a hydraulic fluid too.. with varying compatibilities between the DOTs. you can't mix some of those.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
1982 928 us
temps too p s fluid might not keep parts cool ? -- castrol.com stay left follow clicks, and/or if you put your arrow to the right on those right pics theyll start talking to you..... and/or scroll to bottom left which oil to buy you can enter specific car...
1982 Porsche 928 us Last edited by lfausty; 10-20-2011 at 09:56 PM.. |
