Rev Limter? Do we even have one?
After listening to my new love for this Ferrari 355 and exhaust system. I have never heard a 928 hit it's Rev Limiter. Do we even have one besides the engine blowing up?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Network Native
Yup, some have a thing I think in the distributor, others the brain, easy to find with the Euro S motor. One I think retards the spark a bunch, and other maybe turns off injectors, but can be diddled with sharktuner.
The thing is, I never heard a Shark "hit" the Rev Limiter. Mike, you should do this with your Euro!
I actually toyed with the idea of getting a 355. (the price has come down A LOT). Then I talked to a guy that owned one.. it needs a $10k timing belt change at very short intervals (I want to say 12k miles bit I don't remember). oh, it's only $3k in parts if you want to pull the motor and do it youself. I drove away happy with my 928 again
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
You have to pull the motor to do a TB?
yup, mid engine.
Meh, can't be harder than pulling a 928 Engine. I still have nightmares
oh yeah it is a lot harder than pulling a 928 engine. The engine, transmission, and rear suspension are all one piece that has to come out in one big and very heavy lump.... so you have a lot of weight, a lot of complexity, no space, a lot less documentation on how to do it than a 928, far more expensive parts, no non factory sources for many of the parts...around here the going rate for the engine R&R is $10k....PLUS parts. A friend bought a 1999 355 a couple of years ago, it had 7000 miles on it...first trip to the repair shop for a "post PPI" (bad concept but the car was so new and so cheap he took the chance) netted him the timing belt replacement, and all its associated costs.....and gave me the opportunity to look at the process in detail. My first opinion, before seeing what had to be done, was it can't be that difficult....WRONG! What a process...
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red) Last edited by tmpusfugit; 10-16-2011 at 05:57 AM.. |
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
The 16v 928's have a rev limiter in the stock ignition rotor. It is spring loaded and breaks contact at high RPM. If you've replaced your stock rotor with an aftermarket piece, you no longer have a rev limiter.
1984 928's w/ 5 speed Smoked Quartz Metalic 1982 928's Turbo w/ 5 Speed Platinum Metalic 1978 Euro Widebody w/ 5 speed Guards Red |
Here's a thread with someone replacing the TB with engine "in" car. Also, states that there was plenty of room in that area. It says to drop the tanks. Although no pics were taken.
Found some pics of tank remove and TB View
Is there a video of a 16v 928 hitting the Rev Limiter? Does it sound the same? Just curious.
damn, I should have bought one, that looks like something I could do. It's nice to see that they get cranky on the Ferrari forum too
Looks a lot easier than dropping the engine/transmission/rear suspension....
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red) |
They do say it's a byotch to drop the tank, but then again, it's Ferarri guys talking, not 928 guys
Not sure about the later Euros, but the early Euros had the rev limiter in the rotor. If a US rotor has been installed, there will be no rev shut off. All US 928's have the rev limiter built into the ignition module to shut off the spark at about 6300 rpm.
Dennis |
...but what does it sound like? Does it just shut the ignition down and the car dies? Or does it sound like the Ferrari above and do intermittent cuts and just doesn't go above 6300 rpms?
On the euro the ignition will cut off until the rpm decreases enough for the spring to close. I can't remember hitting the limiter on my US 928, but on my 931, the ignition shuts off until you lift the accelerator. Think it's tied into the WOT switch.
Dennis |
Hi,
I've reached the red zone once or twice and it's an intermittent cut until you lift the accelerator. That cut is made by the distributor rotor. I've replaced mine a few months ago with an original one and this rotor it's a little different from a "normal" one. Regards
1983 928S 5 speed Euro Ruby Red Metallic / Grey Beige |
